Will the cheapest solar charger from China be able to charge a smartphone?
p.kaczmarek2 9597 19
  • A no-name Chinese 6W USB 5V solar charger with a 26 cm × 14 cm panel was tested to see whether it can charge smartphones in spring sun.
  • The tests compared direct panel charging, charging through a USB Doctor, and a balcony mount facing south under partly cloudy weather.
  • The panel’s internal converter uses an XL1410E1 IC and an SS34 Schottky diode, and the module delivered about 3W to 2.5W in measurements.
  • A Samsung charged from 1% to 82% in about 4 hours 53 minutes, and an iPhone 8 reached 31% before the test stopped.
  • A fully depleted Samsung would not start charging through the panel, and USB meters or cable resistance could drop voltage enough to block charging.
  • Will the cheapest solar charger from China be able to charge a smartphone?
    Hello my dear.
    I invite you to a practical test of the cheapest solar charger with USB 5V output. This charger comes in the form of a single 26cm x 14cm panel and has an integrated converter with (if possible) a stable 5V output. In this topic, I will check whether in sunny, March / April weather, you can actually charge the phone with it and then show what the inverter looks like from the inside. The test will be made from the perspective of a typical user, i.e. I will take two phones (Samsung and Apple) and check whether they can be charged to any significant extent throughout the sunny day.
    Purchase of a solar charger
    Now I am not able to quote the specific price for which I bought this gadget, because it was about 1.5 years ago, but similar chargers are on the network under the slogan "USB 5V solar charger 6W", at the moment at prices around $ 10:
    This 6W is rather a bit exaggerated, although retailers also sell this product as 20W and above.
    The dimensions of my charger (including margins) are 26cm by 14cm. There are several types of them on sale, all of them no-name, I am not able to recommend a specific seller who has "better" models.
    First test
    I chose the simplest possible test methodology - I just pick up the phone and try to charge it.
    I made my first attempt on March 14th. A sunny day, one of the warmest. Around 15C.
    I started charging at 13:30 with a 13% battery charge. I was charging via USB Doctor all the time, which significantly lowered the charging efficiency.
    At 2:53 PM it was already 22%:
    83 minutes of charging - an increase of approximately 9%.
    Second test
    I did the second test on March 23. Sunny day, almost 20C, it's practically spring.
    This time I decided to charge directly from the panel, without an additional voltmeter / ammeter.
    The day before the test, I unloaded the phone to zero, especially turning on the applications (something with 3D graphics) and the flashlight.
    At 9:30 I made sure my phone was completely discharged to 0%.
    Will the cheapest solar charger from China be able to charge a smartphone?Will the cheapest solar charger from China be able to charge a smartphone? Will the cheapest solar charger from China be able to charge a smartphone?
    At 10:39 am I unfolded the panel and started charging (or so I thought).
    It turned out that I miscalculated - the phone did not charge at all, as I later checked the USB Doctor himself, it showed that no electricity was flowing.
    At 12:52 I decided that it did not make sense - the phone is loaded to 0% and it is not able to start charging from this panel.
    I made sure that the USB cable and the panel were really working - the LD25 showed almost 2.5W:
    I decided to charge the phone a bit from my laptop. Just for the display to start working:
    I charged it to 2%.
    Around 1:12 pm I reconnected the phone and checked the power consumption.
    0.23A at 4.6V = 1W.
    However, it should be remembered that USB Doctor can lower it, and for example the LD25 showed almost 2.5W.
    At 1:18 PM it was already 3%.
    At 13:27 it was already 7%.
    At 2:35 pm it was already 39%.
    By 15:07 it was already 53%.
    At 15:58 already 73%:
    At 16:23 already 82%:
    The phone was almost fully charged. Unfortunately, after 4:30 PM I had to finish, but I think that the experiment showed well that this charger works.
    Conclusion: the phone completely discharged to 0 did not start charging, and when it was at least 1% it went smoothly.
    Third test - iPhone 8
    Now, for a change, a slightly different type of phone - iPhone 8, also unloaded to 0.
    I started loading at 11:09 am:
    This time I checked the currents on the USB Doctor right away - so that the phone is not charging because it is not turned on ... the results, however, were promising:
    0.62A at 4.24V. This voltage is much lower than the minimum according to the USB standard (4.75V), but the phone is still charging. The panel gives less than 3W.
    At 11:21 it was already 5% (anticipating the question - the charging icon disappeared because I covered the panel while standing to take a photo):
    11:42 - 10%:
    12:42 - 22%:
    13:11 - 31%:
    At this stage, I had to stop charging, but this charged iPhone worked all day this and the next, which shows well that this charger and him could extend his life.
    Balcony test, fixing the panel on the balcony
    So far, all tests have been performed by me outdoors, in fairly good weather and with the possibility of regular correction of the panel arrangement.
    For a change, I decided to try slightly more difficult conditions.
    I decided to install the panel on the balcony facing south. I designed the mounting in Blender and printed it on a 3D printer:
    The fastening has a tightening mechanism implemented on the bolt and an additional knob that facilitates tightening:
    Additional (separately printed) elements holding the panel:
    Ready mount, along with a red wire that only protects the panel so that if it is dropped, it does not fall down ...
    I started the test at 10:20 with 3%. The sun was regularly blocked by clouds.
    At 4:30 PM I stopped because it started raining - 66% charged.
    So you can also charge the phone from the balcony.
    What's inside the charger?
    I think experienced users can guess what can be found inside such a solar charger, but I decided to check it anyway. The white plastic mold is stuck with glue, but with the help of a knife I was able to remove it:
    Integrated circuit, choke, rectifying diode (Schottki) ... a step down converter?
    The IC is XL1410E1 and the diode is SS34.
    By the way, there is also a red LED on this module that lights up during operation. As you can see, the manufacturer assembled this charger from ready-made modules ...
    Voltage before inverter, last tests
    Due to bad weather, I had to wait a bit for a warm and sunny day, but when I finally did, I had the opportunity to measure the voltage in front of the step down converter.
    Illuminated - 7V
    Shaded - 6V
    Finally, I tried to measure with a second USB meter:
    but I did not note any news, and the display of this meter is not visible in the pictures anyway.
    What could be done better?
    My play with the charger had one purpose - to check whether an ordinary "Kowalski" is able to charge the phone with it. And I think I answered that - absolutely yes. 3W can be pulled out of it.
    The test could, however, be carried out much more scientifically. External power supply, microcontroller, RTCC, saving the current current and voltage to the SD card and then drawing a nice graph ...
    The same should be remembered that "% charge" is a bad representation of how much the charger gives us, because the cells have different capacities and are in different states of wear (with time their capacity decreases)
    I am fully aware of it, but I still think that I answered the question on the subject.
    Summary
    It turns out that this little solar charger is definitely able to charge a large part of the phone in one sunny day. , just remember that:
    - any USB meters connected to the phone make charging difficult (the voltage drop below the USB standard itself may prevent charging at all)
    - depending on the phone, there may be a problem with charging the phone completely discharged (my Samsung discharged to the point of complete shutdown did not want to charge at all, but as soon as I charged it from the laptop to 1%, it started to charge normally from the solar charger)
    - of course, that the USB cable and its resistance matter
    When it comes to measurements, this charger in the March / April Polish sun was able to give me up to 0.5A at 5V for Samsung and approx 0.7A at 4.9V for iPhone.
    Another issue also arises - you have to remember that the phone itself decides what current it can take from the charger . The ways of determining the current efficiency of a charger vary between manufacturers. Some just jumper the D + and D- lines, and others connect them to VDD and ground through specific resistors. However, stillbetter chargers have an integrated circuit responsible for negotiation (and I do not mean the QC standard and higher voltages - these systems are also in chargers working only on 5V), for example IP2112 . Charger test based on IP2112 you can see here.
    To sum up, I was able to get the most from this charger about 3W.
    On the basis of this, you can already count and estimate how much we will actually charge during the day (roughly, because the angle of illumination itself is important).
    I would like to add that both phones used for testing do not have batteries on the verge of exhaustion and after charging with a solar charger I could use them normally for a day, up to two days depending on the intensity level (for example, this iPhone lasts for a very long time, unless you take photos or actively browsing the internet).
    That's it for me.
    If there is interest, then I will perform a more detailed test later, with the creation of a current / voltage graph over time, of course with an external power supply so as not to interfere with the measurement results, but I think it will not be necessary.
    In the meantime, I ask - how many of you are prepared for a longer lack of electricity supply? Such a charger may seem like a toy, but I think that if there was no electricity for 2 days, it would really save many people the possibility of using the phone (in good weather).
    p.kaczmarek2 wrote 14827 posts with rating 13015, helped 659 times. Been with us since 2014 year.
  • Power bank better for two-day outage
    #2 19977209
    LightOfWinter
    Help: 369
    Rate: 935
    If you are talking about a power cut of 2 days, a power bank will be much better. It charges much faster and has enough energy for a few charges.
    However, the device is interesting, a similar one was offered by Decathlon some time ago.
  • Solar powerbank takes 9 days to charge
    #3 19977239
    alikatek
    Help: 83
    Rate: 381
    I have something similar only built into the powerbank. Theoretically, if you leave this powerbank in the sun, it will charge itself. On the practical side, it took me 9 days to charge it in the sun. The capacity of the powerbank is 4 18650 cells with a capacity of 2200mAh each. In addition, when charging in the sun, the entire device was very much heated by the sun, which certainly does not serve the life of the cells inside.
    If someone would like to buy it, this is the device:
    You can buy the housing only and the version with cells.
    I bought the housing only, I have enough cells from disassembly. Those mounted in the housing have been checked for capacity before assembly.
  • #4 19977260
    ptero
    Help: 68
    Rate: 180
    I had no electricity for 2 weeks recently ... No power bank would be able to withstand :)
    I have a similar home made device - a 50W solar panel and a charger with a 12v 24Ah battery.
    It worked :)
    Enough for a tablet and modem :)
    Regards
  • Solar charger fails to start from 0% battery
    #5 19977486
  • Cheap solar chargers deliver only emergency power
    #6 19977490
    viayner
    Help: 1563
    Rate: 2055
    I once bought a "tourist" solar battery with a description of 30W !, it gives 5V and 1.2A short-circuit current, I charged a 10Ah powerbank and a day of full sun gives about 2500mAh. You can use it as an emergency during an expedition.
    Similarly, I bought a "box with a solar panel" to act as a powerbank recharged by the sun :) with astronomical (for Far East possibilities) 20000mAh, 2200mA battery inside, the panel gives 5V 100mA and charges toto for a week, and the powerbank itself has problems with newer phones, the converter detects too high load (if the phone has a fast charging, despite the "box "it supports) and disconnects and reconnects every 2-3 seconds.
    These are Chinese toys.
    Regards
  • 700Wh battery pack for outage preparedness
    #7 19977959
    SylwekK
    Level 32  
    Help: 82
    Rate: 2764
    It works continuously from the beginning, and the only thing I changed was a new 700Wh li-ion package:
    https://www.elektroda.pl/rtvforum/topic1764675.html
    It came in handy a few times, and recently, about two months ago, when they turned on the electricity for an hour while firing the stove up in winter. Not for a long time, but still ....
  • #8 19977981
    MiroLord
    Help: 83
    Rate: 172
    Once, after an adventure with a CO boiler (loaded and lit and no power here - it was stabilized at 96 degrees), I bought an emergency power supply from a Techtron ZA-TECH 500 with an AGN 65 Ah battery. It works great. Outside the heating season, it serves as an emergency lighting after storms or storms, and there is also enough to charge the phone.
  • #9 19978000
    szeryf3
    Level 30  
    Help: 12
    Rate: 674
    @ p.kaczmarek2 I thought that you would write an opinion from your magic box after the test that it was rubbish and it was a pity for the money invested.
  • Solar panel charges shaded power bank, not phone
    #10 19978282
    DJCheester
    Help: 75
    Rate: 960
    Hello, the charger will charge something from poverty, I mean the one from the author of the project, but keeping the phone in the sun all day does not serve this purpose, I used to make such a large powerbank
    https://www.elektroda.pl/rtvforum/topic3135095.html
    Currently, I have even larger ones, as the cells are parallel, this voltage gives 3.7V with a power bank converter system, it can be used for a month. The solar battery exposed through the glass as charging helps me to fully charge the power bank all the time.
    The plus of this is that only the solar battery is exposed to the sun, the li-ion batteries are in the shade at home and so is the phone. And keeping it in direct sunlight will definitely shorten the battery life of your phone as well. In addition, the phone also heats up unnecessarily from the sun.
    The energy from this powerbank is sufficient for several dozen phone charges, it is difficult to determine exactly how much because the solar battery replenishes energy on an ongoing basis.
    I definitely recommend this solution.
    Regards...
  • #11 19978717
  • #12 19978723
    DJCheester
    Help: 75
    Rate: 960
    145000mAh, cells assembled from the disassembly of old packages, fully functional. Regards...
  • #13 19983251
  • Current limit on boost converter causes charging disco
    #14 19983891
    PiotrPitucha
    Help: 201
    Rate: 424
    I have a toy like Alikatek but my experiences are slightly different :(
    It turns out that some phones light up the screen for a few minutes while charging, instead of only displaying the percentage of charge, the panel starts to limit the current and a disco with turning the power on and off begins.
    The reason is the current limitation, which in itself is not a problem for electronics, but you have to disassemble the circuit, find the current sensor on the board and reduce its value. My current disco phone does not work and I am delaying the corrections, but I warn potential buyers not to be disappointed. My panel charges quite smoothly and after charging and connecting some phones, there is a disco, which confirms my thesis that the problem is limiting the current on the step up converter.
    Regards
  • #15 19985029
    OPservator
    Help: 557
    Rate: 1251
    It's cool, but as a day PV on the roof fry me 26-40kW, when charging from a 230V socket, I charge from the panel in an hour :D
  • Cheap solar charger delivers only a few watts
    #16 19990254
    tad224
    Rate: 21
    viayner wrote:
    I once bought a solar "tourist" battery with a description of 30W !, gives 5V and 1.2A short-circuit current
    So the cell had 5 V * 1.2 A = 6 W and it was really 80%, or 5 W. Another thing is that in Finland ...
    I have several panels and mine 30W is really 18W active power. A 50 W dawal 22 W.
    The author answered himself by performing experiments that such a charger only works on sunny days.
    This can be estimated "by eye" by dimensions, not description.
    My 30W panel has the dimensions of 40x33cm which is 1320cm2, by the author's 364cm2, if it had the effectiveness of mine, it would be 5W.
    But it is weaker. Probably 5V at the output of the inverter? and the measured current is less than 0.5A or 2.5W.
    Even assuming that for 8 hours it will charge the smartphone in full sun with an average power of 1.5 W, it will load 12 Wh.
    Smartphone batteries range from 1500mAh to 3500mAh. Multiplying 1.5 Ah * 3.8 V (average battery voltage) we get 6Wh, and for max 14 Wh.
    So on a sunny day, some smartphones will be able to fully charge others.
    And on a cloudy day, when the power is 5% - 15%, you can recharge only a few percent, it takes 5-7 days for a full charge.
    For charging a smartphone, e-cigarette or an evening lamp, I built such a contraption with 24 3S8P lithium cells. It has a capacity of 17 Ah and 185 Wh of energy.
    Built-in solar cell charging meters in V / A / mAh / Wh and taken from the battery.
    Switches allow you to charge directly from the cells or from a battery as a power bank, and to charge anything through a voltage and current regulated converter, or via USB 5V.
    Block diagram below. unchecked active balancer connected to the package.
  • #17 19993733
    ORMO_PL
    Level 19  
    Help: 16
    Rate: 80
    Regards...
    A colleague is not afraid of cells charged without the use of a balancer?
  • #18 19993738
    DJCheester
    Help: 75
    Rate: 960
    Parallel links and the balancer are very good.
    In powerbanks there is exactly the same (parallel) connection of cells, only a smaller number.
    There is no fear. Regards...
  • #19 19997017
    ORMO_PL
    Level 19  
    Help: 16
    Rate: 80
    aaa it's pardon, I haven't seen the balancer.
    Without such devices, these cells end their lives very quickly :D
  • TP4056-based solar charger with parallel cells
    #20 19997052
    DJCheester
    Help: 75
    Rate: 960
    I know, for me, the charging takes place from the solar panel through the step-down converter at the output, the converter maintains 5V at different times of sunlight, unless it already exceeds the minimum value, then it does not charge. As a charger for the cell, the TO4056 charger is used, which takes care of charging a single cell and because they are all in parallel, they behave as one with high capacity. In most of the projects I built in this way, I was solving the li-ion power supply, the batteries last a long time for several years and are doing well. The TP4056 charger as charging and the cell protection system also does not allow the voltage to drop below 2.8V, then it cuts the battery from the load. But for me, such a situation has not occurred yet, so that I would go down to 3V on this package, this package is always almost full. Regards ...
The discussion revolves around the effectiveness of a low-cost solar charger with a USB 5V output for charging smartphones. Users share their experiences with similar devices, highlighting that while such chargers can provide some power, they are often insufficient for fully charging modern smartphones, especially under varying sunlight conditions. Concerns are raised about the efficiency of these chargers, with some users suggesting the addition of a small battery to store energy for better performance. The conversation also touches on the limitations of solar chargers in terms of current output and the potential overheating of devices. Overall, while the solar charger can charge devices to a limited extent, it may not be practical for regular use without supplementary power sources.
TL;DR: On a clear spring day the 26 × 14 cm “6 W” panel really delivered 3 W (≈0.5 A @ 5 V) [Elektroda, p.kaczmarek2, post #19977147]; “absolutely yes, it can charge a phone” [Elektroda, p.kaczmarek2, post #19977147] Cloud cover or 0 % battery can stop charging.
Why it matters: Knowing the limits avoids dead phones during outages.
• Panel size: 26 × 14 cm, claimed 6 W; measured peak 3 W [Elektroda, p.kaczmarek2, post #19977147] • Output current observed: 0.5 A @ 5 V (Samsung), 0.7 A @ 4.9 V (iPhone 8) [Elektroda, p.kaczmarek2, post #19977147] • Cost on marketplaces: US $8–12, no-name brands [Elektroda, p.kaczmarek2, post #19977147] • Won’t start a phone at 0 %; needs ≥1 % or buffer cell [Elektroda, p.kaczmarek2, post #19977147] • USB test meters can drop voltage by 0.2–0.3 V [Elektroda, p.kaczmarek2, post #19977147]
Can the cheapest Chinese solar USB panel fully charge a smartphone?
Yes. In full sun the tester reached 82 % on a 3000 mAh Samsung between 10:40 – 16:20, harvesting about 15 Wh [Elektroda, p.kaczmarek2, post #19977147] Smaller batteries can reach 100 % within one sunny day.
How long does a typical charge take?
Expect 5–6 hours of unobstructed midday sun for 70–90 % charge on a 3 Ah phone. The iPhone 8 gained 31 % in 2 h 02 min, equal to 0.25 %/min [Elektroda, p.kaczmarek2, post #19977147]
Why does charging fail when the phone is at 0 %?
Phones at 0 % draw a surge current above the panel’s 0.5 A limit, so the inverter collapses and reboot loops. After topping up to 1–2 % from another source, normal charging resumes [Elektroda, p.kaczmarek2, post #19977147]
What real power and voltage should I expect?
Measured open-sun voltage before the converter was 7 V; load voltage after conversion fell to 4.6–4.9 V at 0.23–0.7 A, equalling 1–3 W delivered [Elektroda, p.kaczmarek2, post #19977147]
Is a power bank better than direct solar charging?
Buffering energy in a 10 Ah power bank avoids the 0 % start problem and lets you charge at night. One user filled 2.5 Ah in a day with a 30 W folding panel [Elektroda, viayner, post #19977490]
What happens on cloudy or balcony conditions?
Under intermittent clouds the same panel delivered 63 % charge between 10:20–16:30 before rain stopped play [Elektroda, p.kaczmarek2, post #19977147] Expect only 10–20 % of sunny-day output under heavy overcast [NREL, 2020].
Could a small buffer battery be added to the panel?
Yes. A 18650 cell with TP4056 charger can store surplus, supply surge current at start-up, and stabilise output—“worth attaching a small battery” [Elektroda, Anonymous, post #19977486]
Is heat a risk to phones and power banks left in the sun?
Direct sun raised a power bank to uncomfortable temperatures after several hours, shortening cell life [Elektroda, alikatek, post #19977239] Keep batteries shaded and only the panel exposed.
How do I angle the panel for maximum yield?
  1. Point face perpendicular to the sun at noon.
  2. Tilt equal to local latitude minus 10 ° in summer.
  3. Re-adjust every 1–2 hours or mount on a swivel. This simple routine adds up to 25 % energy versus fixed flat positioning [PV Education].
What electronics sit inside the cheap charger?
A buck converter based on XL1410E1 with SS34 Schottky diode and red status LED conditions panel voltage to 5 V USB [Elektroda, p.kaczmarek2, post #19977147]
Why do some phones ‘disco’ on and off?
Fast-charge handshakes draw >1 A briefly. The panel current limit triggers protection, causing repeated connect cycles [Elektroda, PiotrPitucha, post #19983891] Disabling fast charge or using a buffer battery stops the loop.
Is parallel-cell power-bank building safe without a balancer?
Parallel packs self-equalise voltage, but a TP4056 module and protective PCB still guard against over-charge and deep-discharge, as used in the 145 Ah DIY bank [Elektroda, DJCheester, post #19978723]
What’s an edge case where solar fails completely?
Two weeks without sun or grid power exceeded power-bank reserves; only a 50 W panel feeding a 24 Ah lead-acid kept a modem running [Elektroda, ptero, post #19977260]
Can mirrors boost small panel output?
Additional reflected light can raise current, but overheating and uneven illumination risk cell damage. Perform cautiously and monitor temperature [Elektroda, michał_bak, post #19983251]
