[Solved] Sonoff Basic R2 - 10A load for 5-7 hours, is it safe?
willyvmm 1209 2
  • External relay recommended for 10A continuous load
    #1 20060999
    willyvmm
    Help: 164
    Rate: 364
    Welcome.
    I am wondering how the SONOFF Basic R2 will handle a nominal load for a longer period of time.
    I want to control with it a device that will be switched on once a day for 5-7 hours. There won't be a lot of current consumption at switch-on and switch-off, apart from maybe charging the capacitors of a small switching power supply. After initialisation, the device will switch on a load of approx. 10A for 5-7 hours within a few seconds.
    Apparently 10A is the nominal load ... However, on a "GOLDEN made in china" relay, is it better to connect an external power relay.
    SONOFF Basic R2 Datasheet: ?????-BASI...1218-1.pdf (627.44 kB)You must be logged in to download this attachment. .
    Rysio4001
    Heating systems specialist
    Help: 617
    Rate: 1077
    Better to use an additional relay/contactor.
    This 10A, is the allowed maximum load, so it will be loaded with a limiting current. Also, manufacturers usually give the maximum value for a resistive load, and here you are supposed to have a switching power supply, which has a different nature of load.
    Greetings.
  • #3 20062630
    willyvmm
    Help: 164
    Rate: 364
    Thank you.
    You just confirmed my doubts. An additional relay is essential in this configuration.
