[Solved] Will the Tuya WiFi switch work on "another" WiFi network?
palmus 1896 2
  • #1 20406728
    palmus
    Help: 233
    Rate: 752
    Hi.
    The device is in a place with wicked, fading wifi.I want to put an old router in there as an AP over the cable. I will set the same wifi password and SSID as in the router.Will this switch in this network work with the rest of the devices on the "main" network?
    K3
    Level 30  
    Help: 153
    Rate: 429
    If it's the same SSID and password then it should connect without any problems. After all, this is how wireless networks with greater coverage are built.
  • #3 20481697
    palmus
    Help: 233
    Rate: 752
    I fought, it turned out that the cable to the router sometimes did not connect.After replacing everything worked and is functioning.Thanks a lot.
