[Solved] ESP32 and Aduino IDE (under Linux) - ModuleNotFoundError: No module named 'serial'.
CC_PL 1275 4
  • #1 20510139
    CC_PL
    Rate: 57
    I have an Arduino IDE under Linux (in the form of APPIMAGE - in one file) and I am using ESP32.
    In the Arduino IDE I get an error (when trying to verify the code):
    Traceback (most recent call last):
    File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool.py", line 31, in
    import esptool
    File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/__init__.py", line 41, in
    from esptool.cmds import (
    File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/cmds.py", line 14, in
    from .bin_image import ELFFile, ImageSegment, LoadFirmwareImage
    File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/bin_image.py", line 14, in
    from .loader import ESPLoader
    File "/home/cc/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/loader.py", line 30, in
    import serial
    exit status 1
    Compilation error: exit status 1
    It appears that the Arduino IDE uses a Python in which there is no pyserial, but I don't know how to check which Python the IDE uses.
  • #2 20510158
  • #3 20510587
    CC_PL
    Rate: 57
    3.9.12 on Linux (system), but I also have Anaconda and I don't know if the Arduino IDE doesn't have its Python? I can't open the terminal from within the Arduino IDE.
  • #5 20510898
    CC_PL
    Rate: 57
    OK, problem solved. You need to install the Arduino IDE from the Ubuntu Software application. The "portable" version in the form of the AppImage file doesn't quite work (even though it was downloaded from Arduino.cc).
