[BK7321N/CBU] Aubess RGB-CW-IC LED Strip: Flasher Tool Magic Header Issue and 2MB Dump Analysis
bobthemonkee 1686 1
  • Flasher tool rejects dump for missing magic header
    #1 20590352
    bobthemonkee
    Hello again!
    I have an Aubess LED Strip with CBU chip that I have a 2mb dump for. The flasher tool says that the "magic header" is not in the bin file. So, I figured I would post it here for another look.
    One dump was done with the flasher tool and one was on my RPi using a different tool. Both showed the same result in the flasher.
    Here is the listing for the item:
    https://www.amazon.com/gp/product/B0BZRCDNWH
    Thanks in advance for the help!
    [BK7321N/CBU] Aubess RGB-CW-IC LED Strip: Flasher Tool Magic Header Issue and 2MB Dump Analysis [BK7321N/CBU] Aubess RGB-CW-IC LED Strip: Flasher Tool Magic Header Issue and 2MB Dump Analysis [BK7321N/CBU] Aubess RGB-CW-IC LED Strip: Flasher Tool Magic Header Issue and 2MB Dump Analysis
    • readResult_BK7231N_QIO_a_2023-22-5--09-10-49.bin (2 MB) You must be logged in to download this attachment.
    • aubess.bin (2 MB) You must be logged in to download this attachment.
  • #2 20590553
    Rate: 12906
    Thank you, it's a very interesting flash dump. From a quick glance, it looks like the Tuya config partition is indeed missing from that one.
    After a brief search, it seems it's a non-Tuya product. It's not using Tuya SDK at all, it's using RT-Flash, as some string references suggest:
    RT-Thread flash abstraction layer
    Are you able to get TX2 log at 115200 baud rate from this device?
