Using WIFI smart switches in the garden - Immax NEO 07746L or another option?
ppolec 1041 3
  • Need IP68 Wi-Fi switches for seven garden loads
    #1 20685399
    ppolec
    Hi esteemed group members
    I have a query for you, because I am looking for the possibility of connecting several on/off sources (each separately) - about 7 pieces using an application and WIFI connection - lamps + sockets.
    The current is routed but I would like to be able to decide which item is on and which is not (if with the connection to the schedule is already a fairy tale).
    I want to be able to use this in the garden so the switch must have a suitable degree of protection and WIFI range of about 50 meters.
    Searching on the internet and I'm not sure about my choice.
    For the moment I found the item: Immax NEO 07746L - IP68 WIFI Tuya - price about 120 zł per piece
    Does anyone have experience with this or is able to advise something else interesting?
    Of course you can use a smart socket but I was thinking rather of such a switch because I need 5 of them and the sockets only 2 pieces.
    A combination of socket or switch depending on the need from one company would be ideal
    Thank you in advance for your help and suggestions.
    Greetings
    Paul.
  • #2 20685491
    sosarek
    Help: 9320
    Rate: 15532
    All cables coming together in the switchboard?
    You have Tuya, Supla, Sonoff....
    Z
    Pka, Poznań, 60-850
  • #3 20686913
    ppolec
    It's not that simple
    One line goes out from the house to the garden and then one line around the house and there I want to get the control.
    What I want to have controlled as separate I have to make a tee (1) input (2) voltage to control the lighting, (3) line further going around the garden and only the control goes to number 2 - on/off
    Thanks
