Relay for 12V DC and 240V AC with HomeAssistant, Zigbee, MQTT, Conbee2, Manual Control
darekpublic 1236 2
  • Clarifying relay options for manual control and status LED
    #1 20688608
    darekpublic
    Hi.
    I am looking for 2 solutions and kindly ask for help in selecting components:
    1. Relay (1 or even better: more channels) compatible with HomeAssistant + Zigbee + MQTT + Conbee2 for 12V DC - for switching devices in a 12V camper installation. Is there any possibility that this relay, in addition to operating from HA would also work in manual mode - i.e. I would add a physical button to open/close the circuit. For this I would like to have a physical diode to be installed somewhere in the panel, which informs about the status of the relay.
    2. Same as above but for 220-240 AC
    Ideally if this would draw as little current as possible. These solutions must be super-safe so that I can leave it unattended in a wooden camper.
    Greetings,
    Darek
  • #2 21754581
    piotrfirlej
    Have you finally found something for point 1?
