Application kiosk mode on Raspberry Pi with Home Assistant and Iiyama T2251MSC-B1 monitor
dawidbajek90 1482 4
  • #1 20733665
    dawidbajek90
    Level 4  
    Hello I would like to install kiosk mode on a raspberry pi and integrate with home assistant. I have some questions about the solution I would like to use. I would like to add that I am a beginner in this topic.
    1) I would like to use an Iiyama T2251MSC-B1 monitor for the raspberry, but I don't know if it will be compatible for this.
    2) Will 2gb ram and 32gb on the device memory card be enough?
  • #2 20733702
    JacekCz
    Help: 760
    Rate: 1464
    Image output from RPI to monitor will work
    Touch implementation .... it's more a question of not the system, but whether the application can.
    For traditional console 2 GB RAM will be sufficient in situations that I can reasonably imagine.
    For a complex graphics application ...
    It will be frogged, I think.
  • #4 20733709
    JacekCz
    Help: 760
    Rate: 1464
    sosarek wrote:
    If the touch works with a USB mouse - it will work.
    Mice, but there are subtleties (I know this monitor on Windows).
  • #5 20733710
    sosarek
    Help: 9320
    Rate: 15532
    Lately, a plethora of touchscreen monitors for POS systems can be found on portals.
    Z
    Pka, Poznań, 60-850
