  • #1 20742678
    stefbut
    Rate: 98
    For a fan that has 3 taps.
    I am looking for a WiFi controller / relay that will independently switch gears 1 2 3. At the moment this is done mechanically and I would like to control via Tuya etc. There are a lot of such devices on the market, but I don't see one that has the operation of only one contactor at a time , because if you accidentally switch on two at once the motor will burn up.
  • #3 20742763
    stefbut
    Rate: 98
    Yes but they work at the same time because there is no
    block and they burn up the engine
  • #5 20742772
    stefbut
    Rate: 98
    Ok, let me ask you for an example of such a device - I don't know about this - I know you can do everything, but if I did, I wouldn't start a topic on the forum.
