Implementing Automatic Bathroom Lighting with Tuya Door and Motion Sensors
Szyszkownik Kilkujadek 4263 17
How can I automate a bathroom light in Tuya so it turns on when the door opens, stays on if motion is detected after the door closes, and turns off only after 15 seconds of no motion?
No, not reliably with standard Tuya/Smart Life scenes; the thread says Tuya scenes are too primitive for this door-plus-motion state logic and one condition can collide with another [#20764836] A theoretical setup would need a Wi‑Fi relay for the lamp, a Wi‑Fi door limit switch, a Wi‑Fi motion sensor, and a timer in a Smart Life scene, but that was described only as a rough possibility rather than a solid solution [#20763552] Another reply says Tuya-style parts are not suitable for this kind of automation because unpredictable cases will always break it, and that only industrial automation hardware would be dependable, though it is expensive [#21542288] Suggested simpler alternatives were a plain motion sensor with a shutdown countdown or switching to an mmWave presence sensor [#20764836][#21543719]
  • Proposed Tuya logic for door and motion lighting
    #1 20763135
    Level 37  
    Help: 211
    Rate: 1016
    I am looking for an idea how to implement automatic control of bathroom lighting in a TUYA system using a door opening sensor and a motion sensor.
    Principles:
    1. After opening the door, the light turns on.
    2. The door closes - the light is on.
    3.
    a) If within e.g. 15 seconds after closing the door no one moves, the light goes out.
    b) If within the above time someone moves, the light remains on without time limit.
    4. Opening the door causes a return to pt. 1.
    How does this work? In short: if the motion detector detects movement when the door is closed, it means that for sure until the door is opened someone is there.
    Does anyone have an idea how to implement this in TUYA? Is it possible to do this without HA?
  • #2 20763475
    Level 37  
    Help: 211
    Rate: 1016
    @jurp maybe you can give a bit more detail?
    Added after 1 [minute]:
    @ElektrodaBot can you help? This is about the problem with #1 ?
  • Smart Life scene using door and motion sensors
    #3 20763552
    sumara17
    Help: 19
    Rate: 86
    This can theoretically be done using the Smart Life app. A scene needs to be created. Of course, the lamp would have to be switched with a Wi-Fi relay. Also, a curb switch with Wi-Fi communication and a motion sensor also with Wi-Fi communication would have to be added to the door. A scene should then be created in the app. In the scene, it is also possible to enter a timer.
    The switching on and off of the relay must be made dependent on the limit switch and the motion sensor by additionally entering a timer.
  • #4 20763621
    Level 37  
    Help: 211
    Rate: 1016
    I know what is needed and I already have it.
    I just don't know how to set up such a scene.
  • #5 20764836
    12robert12
    Help: 134
    Rate: 179
    Tuya has very primitive scenes and capabilities...
    If you start a scene (meet the conditions) then the task executes,
    So your 1st condition already conflicts with the 2nd condition, it is not possible to stop 1 scene in Tuya
    Maybe just the motion sensor itself and the countdown to shutdown is enough,
  • #6 20764860
    Wojtek M
    Help: 520
    Rate: 1127
    Why complicate simple things! One simple switch is enough.
  • Single switch proposed for bathroom lighting automation
    #7 20765650
    Level 37  
    Help: 211
    Rate: 1016
    12robert12 wrote:
    If you run the scene (meet the conditions) then the task executes,
    So your 1st condition already collides with the 2nd condition, it is impossible to stop the 1st scene in Tuya
    Not true. Nothing here conflicts. Just this part of the control I already have, because it is the easiest to do.
    12robert12 wrote:
    Maybe just the motion sensor alone and the countdown to switch off,
    Not enough, especially in rooms like the bathroom.
    Instead of a motion sensor you can give a microwave presence sensor, but this solution does not interest me.
    This is very interesting. Can you tell how one switch can implement such automation?
  • Tuya scenes too primitive for bathroom automation
    #8 20765694
    12robert12
    Help: 134
    Rate: 179
    Szyszkownik Kilkujadek wrote:
    I know what is needed and I already have it. I just don't know how to set up such a scene
    12robert12 wrote:
    If you run the scene (meet the conditions) then the job is done,
    So your 1st condition already collides with the 2nd condition, it is impossible to stop 1 scene in Tuya
    Not true. Nothing here conflicts. Accurate this part of the control I already have, because it is the easiest to do.
    What do you mean? show how you wrote this scene :) , upload screenshots
    because you contradict yourself in your posts
    Different modules have different capabilities, but the Tuya scenes themselves are too primitive to do such things as you want,
    This is very interesting. Can you tell how to implement such automation with one switch?
    It is probably about a simple traditional switch,
    but such a fashion today, to automate even the light in the toilet :) when the wifi is not available, you will sit in the dark ... :) :) about the delays in the execution of tasks does not write, once it worked in 1s and the other time after 30s
  • Need details on devices and automation platform
    #9 20765696
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 368
    Rate: 960
    12robert12 wrote:
    help?
    but such a fashion nowadays to automate even the light in the toilet :) when the wifi runs out, you will sit in the dark ... :) :) about the delays in task completion, once it worked in 1s and the other time after 30s
    Welcome to the Elektroda.pl forum!
    I definitely understand your point of view. Automation can be great, but when technology fails, things can quickly become frustrating. With home automation systems such as light switches, reliability and predictability are key, and delays can be really annoying.
    It sounds like you've encountered an automation problem that is causing intermittent delays in system responses. To help you, I would like more information about your system. Can you tell me what devices and applications are involved in your automation process? Are you using an IoT (Internet of Things) system such as Google Home, Amazon Alexa, or perhaps a local Raspberry Pi or ESP8266/ESP32-based solution? Does the latency occur on every attempt, or only in certain circumstances?
    Some potential causes could include WiFi issues (which is ironic, given your comment about sitting in the dark when WiFi is down!), latency due to server overload (if you are using cloud services), or even issues with the device itself, such as overheating.
    I look forward to hearing more from you so we can spend more time diagnosing and solving your problem. Remember, I am here to help!
  • #10 20895138
    Ramotny
    The system resembles a staircase timer where one excitation is the bell button at the entrance and the other is the PIR detector in the bathroom and that's it.
  • #11 21164335
    Marek Sp
    Rate: 139
    Maybe a processor that reads the switch and the motion sensor ?
  • #12 21165644
    Level 37  
    Help: 211
    Rate: 1016
    Marek Sp wrote:
    Maybe a processor that reads the switch and motion sensor ?
    I do not want any additional DIY components.
    I would like to solve this using only official and readily available Tuya / SmartLife devices.
  • #13 21165862
    Marek Sp
    Rate: 139
    Well your will only with this more trouble than good in my opinion.
  • #14 21180957
    Zbino
    Rate: 9
    For the bathroom, the best solution is a light switch that counts the number of people entering and leaving the room. The Luno7 for example has such a function. In my opinion, this is the best solution because you don't have to move in the bathroom. You can sit on the throne without moving or be locked in the shower cubicle and the light will not go out.
  • Combining door and motion sensors to avoid false offs
    #15 21182899
    Level 37  
    Help: 211
    Rate: 1016
    @Zbino thanks for suggesting an alternative solution. The method for counting people has been known to me for years and it has one major drawback. The device, even if it has directional recognition, is unfortunately not immune to the situation when two people pass each other in a doorway. It is also not immune to several other human behaviours, but never mind that.
    That's why I'm combining with a motion sensor and a door.
    If someone moves in the room after the door is closed, we can be sure that the light does not have to be switched off until the door is opened. Even if someone falls asleep in the bathroom, the light will not go out.
    There is a small chance that someone inside the room will not move for, say, 15 seconds after closing the door.
  • Industrial automation or people counter recommended
    #16 21542288
  • #17 21542302
    Level 37  
    Help: 211
    Rate: 1016
    I know the disadvantages of the radio-based motion sensors here. Unfortunately I think I will let the subject go.
  • #18 21543719
    ferbulous
    Help: 8
    Rate: 56
    Better stick to mmwave sensors for bathroom presence
The discussion addresses implementing automatic bathroom lighting control within the Tuya ecosystem using a door sensor and a motion sensor. The desired logic is: light turns on upon door opening; remains on after door closes; if no motion is detected within a set delay (e.g., 15 seconds) after door closure, the light turns off; if motion is detected, the light stays on indefinitely until the door reopens. Tuya's native scene capabilities are considered too primitive to fully support this multi-condition logic, as scenes cannot be stopped or combined flexibly. Solutions proposed include using Wi-Fi relays controlled by Smart Life app scenes with timers, but these have limitations. Alternative suggestions involve using a single switch or a people-counting light switch like the Luno7, which tracks entries and exits but can be error-prone with multiple occupants. Microwave presence sensors and mmWave sensors are mentioned as more reliable but are outside the Tuya-only constraint. The consensus is that Tuya devices alone may not reliably implement the complex logic without additional hardware or more advanced automation platforms like Home Assistant. Radio-based motion sensors have inherent drawbacks such as latency and false triggers, making them less ideal for precise bathroom lighting control.
TL;DR: Tuya-only bathroom lighting can work, but latency swings 1–30 s and “Tuya scenes are too primitive.” For Smart Life/Tuya users wanting door+motion control without HA, use timer-based scenes or switch to presence sensing, and expect trade-offs. [Elektroda, 12robert12, post #20765694]
Why it matters: You want lights that don’t time out mid-shower or stay on forever, using only off‑the‑shelf Tuya gear.
Can Smart Life/Tuya do door+motion bathroom lights without Home Assistant?
Partially, but not robustly. Tuya scenes lack stateful logic to latch and cancel conditions. Latency also varies significantly. “Tuya scenes are too primitive.” You can approximate behavior with timers, yet edge cases remain. Consider presence sensing or external controllers if you need deterministic logic. [Elektroda, 12robert12, post #20765694]
What hardware do I need for a Tuya-only setup?
Use a Tuya/Smart Life smart switch or Wi‑Fi relay for the lamp, a door sensor, and a motion sensor. Build automations in Smart Life and add timer blocks where available. This gives you basic on/off control tied to door and motion events. [Elektroda, sumara17, post #20763552]
How do I approximate the 'door + 15 s + motion latch' logic in Smart Life?
Note: This is an approximation due to scene limits.
  1. Door opens → Turn on light (Automation A).
  2. Door closes → Delay 15 s → Turn off light (Automation B).
  3. Motion detected → Turn on light and apply an off timer suitable for bathrooms. This uses delays and timers, but it cannot truly cancel a running scene. [Elektroda, sumara17, post #20763552]
Why is a motion-only countdown often not enough in bathrooms?
People can remain still on the toilet or inside a shower, so countdowns may time out. The OP noted motion-only control is insufficient for bathrooms. Presence sensors can help, but that was not desired here. Use motion-only if simplicity is acceptable. [Elektroda, Szyszkownik Kilkujadek, post #20765650]
What does the 15‑second window achieve?
It acts as an arming period after the door closes. If motion occurs within about 15 seconds, keep the light on until the door opens again. If no motion occurs, turn the light off after that short window. This was the OP’s target logic. [Elektroda, Szyszkownik Kilkujadek, post #20763135]
What’s the simplest, most reliable alternative?
A plain mechanical wall switch remains the most reliable and predictable option. It avoids cloud delays, battery issues, and scene complexity. One forum reply summed it up: use “one simple switch.” Choose this if reliability is paramount. [Elektroda, Wojtek M, post #20764860]
Does the staircase timer analogy fit this problem?
Yes. Treat the door contact and the bathroom PIR as two triggers feeding a timer, like a stairwell relay. That mental model clarifies timing and trigger priorities. It’s useful if you move to hardware timers or PLC-style logic later. [Elektroda, Ramotny, post #20895138]
Are mmWave presence sensors better for bathroom presence?
Yes. Community feedback recommends mmWave for detecting micro‑movements, which helps when users sit still or shower. This reduces nuisance timeouts compared with basic PIR. It fits bathrooms well, though it adds cost and setup. [Elektroda, ferbulous, post #21543719]
Do people‑counting switches fix the 'no movement' issue?
They keep lights on without motion, which suits bathrooms. However, the OP notes a key failure case: “not immune to the situation when two people pass each other.” Crossing traffic can desynchronize the count, causing wrong states. [Elektroda, Szyszkownik Kilkujadek, post #21182899]
Can I just use a motion sensor with a countdown?
Yes. One reply suggested using only a motion sensor and a countdown to shutdown. It reduces complexity but risks timeouts during still periods. Evaluate your room layout and motion patterns before choosing this minimalist path. [Elektroda, 12robert12, post #20764836]
Why might Tuya scenes delay or fail at the worst time?
Cloud latency can swing from 1 to 30 seconds. That variance can leave you waiting in the dark. As one user warned, “when the WiFi runs out, you will sit in the dark.” Local control reduces such risks. [Elektroda, 12robert12, post #20765694]
Should I keep pursuing a Tuya‑only solution?
If reliability is critical, reconsider. The OP ultimately decided to drop the effort due to radio sensor drawbacks. Try presence sensors or different control methods if you want to persist with Tuya. [Elektroda, Szyszkownik Kilkujadek, post #21542302]
What if I need deterministic behavior without DIY coding?
Industrial automation hardware can deliver stronger reliability, but it is not cheap. One user found a people counter works well for fan control, where misfires are less critical than lighting. Consider cost versus benefit here. [Elektroda, Erbit, post #21542288]
Could a small processor solve this cleanly?
Yes. A microcontroller reading the door switch and motion sensor can implement the exact state machine. It enables the latch and cancel logic the Tuya app lacks. The idea was proposed in the thread. [Elektroda, Marek Sp, post #21164335]
