Identifying Power Measurement Pins on RMC021 with BL602 Chip and SM-028_V1.3 Board
bl00dy 1446 3
  • Need help identifying power measurement pins
    #1 20781399
    bl00dy
    I bought this "Mini Smart Socket", which works with eWeLink, not Tuya.
    I successfully updated the firmware to OpenBL602.
    But the socket also needs to measure power. How can I find out which PINs are used for power? Maybe someone can help?
    Ed
  • #2 20783993
    Rate: 12954
    Hello, in case of BL602 we don't have automatic GPIO extraction yet, so you have to just look at the PCB and check the tracks with multimeter. How does your PCB look like? What kind of power measuring chip is used there?
  • #3 20785033
    bl00dy
    Unfortunately, I don't have a multimeter at home. I assume it's a standard BL chip. I can send the original firmware to you.
    Ed
  • #4 20785583
    Rate: 12954
    Hello @bl00dy, then maybe let's check the PCB? Make some more detailed photos? Maybe we will be able to tell from that which pin are used.
