Maintaining a Stable MQTT Connection on WBSL Board with OpenBK7231T SDK: Tips & Solutions
manivalaguru1 2307 13
How can I stop my WBSL/OpenBK7231T device from disconnecting and reconnecting to MQTT every 60 seconds?
To make the MQTT connection stable, first isolate whether your changes are causing the disconnects by testing the latest OpenBeken codebase with a very simple hardcoded publish every 30 seconds; MQTT can drop if you publish too often or otherwise overload the buffers [#20200353][#20205949] If the problem still happens in the unmodified code, try the latest OpenBeken build because the LWIP MQTT library was updated and threading fixes were added for stability [#20549263] Also make sure the device has a unique MAC address, because the logs suggested the MAC may have been cleared by flash erase [#20211558] The maintainer also asked which broker you are using and whether the issue reproduces with the latest OBK build without any code changes, so broker compatibility should be checked too [#20208219] In short: test on clean latest firmware, reduce MQTT traffic, and verify a unique MAC before chasing the BLE/custom-code changes [#20205949][#20211558][#20549263]
  • MQTT disconnects every 60 seconds
    #1 20199074
    manivalaguru1
    @p.kaczmarek2
    i have been using your sdk for wbsl board(smart light) using openbk7231T sdk i can able to control the light and all and changed the formot to support our own broker but problem is it disconnects and reconnects every 60 seconds is there any way to make this connection stable below is the log of disconnection and connection
    Info:MAIN:Time 60, free 102664, MQTT 1, bWifi 1, secondsWithNoPing 0, socks 1/38
    Info:GEN:dhcp=0 ip=192.168.1.102 gate=192.168.1.1 mask=255.255.255.0 mac=d4:a6:51:f3:33:51
    Info:MQTT:MQTT_STATUS=256
    Info:MQTT:my_mac="50:33:f3:51:a6:d4"
    Info:MQTT:blub_data={"RED":0,"BLUE":0,"GREEN":0,"WHITE":10}
    Info:MQTT:mqtt_connection_cb: Disconnected, reason: 256
    Info:MAIN:Main_OnWiFiStatusChange - WIFI_STA_CONNECTED
    Info:MAIN:came to run mqtt every second update
    Info:MAIN:Timer discovers disconnected mqtt 1
    Info:MAIN:CAME TO MAIN
    Info:MAIN:CAME HERE AFTER 60 seconds
    Info:MAIN:Time 62, free 102664, MQTT 0, bWifi 1, secondsWithNoPing 1, socks 1/38
    Info:MAIN:Timer discovers disconnected mqtt 2
    Info:MAIN:Time 63, free 102664, MQTT 0, bWifi 1, secondsWithNoPing 2, socks 1/38
    Info:MAIN:Timer discovers disconnected mqtt 3
    Info:MAIN:Time 64, free 102664, MQTT 0, bWifi 1, secondsWithNoPing 3, socks 1/38
    Info:MAIN:Timer discovers disconnected mqtt 4
    Info:MAIN:Time 65, free 102664, MQTT 0, bWifi 1, secondsWithNoPing 4, socks 1/38
    Info:MAIN:Timer discovers disconnected mqtt 5
    Info:MAIN:Time 66, free 102664, MQTT 0, bWifi 1, secondsWithNoPing 5, socks 1/38
    Info:MAIN:Timer discovers disconnected mqtt 6
    Info:MAIN:Time 67, free 102664, MQTT 0, bWifi 1, secondsWithNoPing 6, socks 1/38
    Info:MAIN:Timer discovers disconnected mqtt 7
    Info:MAIN:Time 68, free 102664, MQTT 0, bWifi 1, secondsWithNoPing 7, socks 1/38
    Info:MAIN:Timer discovers disconnected mqtt 8
    Info:MAIN:Time 69, free 102664, MQTT 0, bWifi 1, secondsWithNoPing 8, socks 1/38
    sta: 1, softap: 0, b/g/n
    sta:rssi=-64,ssid=twtest1,bssid=44:d9:e7:59:f4:2a ,channel=6,cipher_type:MIXED
    Info:MAIN:Timer discovers disconnected mqtt 9
    Info:MAIN:Time 70, free 102664, MQTT 0, bWifi 1, secondsWithNoPing 9, socks 1/38
    Info:MAIN:Timer discovers disconnected mqtt 10
    Info:MAIN:came here to connect again
    Info:CFG:g_cfg.mqtt_pass=demo@2018
    Info:MQTT:pub_payload={"STATUS":"OFFLINE","S_NO":"3350","FWV":11,"MAC":"50:33:f3:51:a6:d4","CONF":{"RED":0,"BLUE":0,"GREEN":0,"WHITE":10}}
    Info:MQTT:mqtt_userName twdemo
    mqtt_pass demo@2018
    mqtt_clientID 3350
    mqtt_host 3.6.105.29:1883
    Info:MAIN:status="OFFLINE"
    Info:MQTT:client_id 3350
    Info:MQTT:client_pass demo@2018
    Info:MQTT:client_user twdemo
    Info:MQTT:mqtt_client_info.keep_alive 30
    Info:MAIN:Time 71, free 102456, MQTT 0, bWifi 1, secondsWithNoPing 10, socks 1/38
    Info:MQTT:MQTT_STATUS=0
    Info:MQTT:mqtt_connection_cb: Successfully connected
    thanks and regards
    manikandan v
  • Frequent MQTT publishes may exhaust buffers
    #2 20200353
    Rate: 12914
    I can clearly see that you are using a modified version of our SDK. Can you provide us more information on:
    1. what exactly was modified (where are you calling the publish from, are you calling it once per frame, or maybe call it too often and exceed the buffers limit?); maybe could you show us your Github repository?
    2. was is working correctly before, before your changes?
    MQTT might disconnect if you are, for example, doing a publish every frame or doing lots of publishes very often
  • #3 20200840
    manivalaguru1
    hello,
    thanks for your reply I have tried to connect with my broker without any changes that code also disconnects and reconnects every minute.
    I have added BLE functionality to SDK other than that everything pretty much the same here is my code base https://github.com/manivalaguru/wbl3/tree/master
    can you please check and get back to me
    thanks and regards
    manikandan v
  • Requesting a fork or pull request for code review
    #4 20200854
    Rate: 12914
    Would it be possible for you to submit your code as a fork of my repository, instead of doing a "fresh" upload?
    I am asking because I wanted to analyze your code but there is no "Diff" (differences since my commits) view and it's hard for me to find all changes.
    Is msg_processor.c the file you added?
    Also, if you need an extra feature, why don't you create a pull request for OpenBeken, then I also could help you with testing on my devices.
    Also, is this an attempt of adding a Domoticz support?
  • #5 20202345
    manivalaguru1
    @p.kaczmarek2
    hello thanks for your reply i have created a pull request in your repo https://github.com/openshwprojects/OpenBK7231T_App/pull/209
    can you please check and get back to me for stable mqtt connection
    have you got time to check this i have got everything else for requirement this is the only thing that is pending
    thanks and regards
    manikandan v
  • Suggesting a hardcoded MQTT publish test
    #6 20205949
    Rate: 12914
    That's really lots of changes. Have you made them yourself?
    You've also broke compatibility with lots of stuff, even the Channel_OnChanged are changed now.
    What is the point of adding linux/lib/rbtree.c to SDK?
    Also many, many changes to new_mqtt and to user_main....
    Well, I'd start with doing a simple test
    I'd suggest you getting latest OBK codebase and hardcoding it to publish your MQTT string, that one:
    	 snprintf(blub_data, sizeof(blub_data), "{\"RED\":%d,\"BLUE\":%d,\"GREEN\":%d,\"WHITE\":%d}",smartblub_config_data.r_brightness,smartblub_config_data.b_brightness,smartblub_config_data.g_brightness, smartblub_config_data.w_brightness)
    Hardcode all values, make it publish that string every, idk, 30 seconds, and then see if the unchanged SDK also disconnects.
    This will allow us to determine whether the issue is also in the original SDK or it happens only in your fork.
  • MQTT disconnects after 360 seconds of no ping
    #7 20208083
    manivalaguru1
    1)yes right now i am only one working on this i have modified mqtt,user main,new_cfg files also added ble functionality so that we can configure wifi and mqtt cerdentials using ble i have also tested OTA that also working fine.
    2) like you said i have tested this with latest obk case but mqtt still disconnects every minute here is the log of connection, disconnection and connection i have only changed wifi and mqtt cerdentials..
    LOG:
    sta:rssi=-61,ssid=twtest1,bssid=44:d9:e7:59:f4:2a ,channel=1,cipher_type:MIXED
    Info:MAIN:Time 410, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 349, socks 2
    Info:GEN:dhcp=0 ip=192.168.1.109 gate=192.168.1.1 mask=255.255.255.0 mac=c8:47:8
    Info:MAIN:Time 411, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 350, socks 2
    Info:MAIN:Time 412, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 351, socks 2
    Info:MAIN:Time 413, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 352, socks 2
    Info:MAIN:Time 414, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 353, socks 2
    Info:MAIN:Time 415, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 354, socks 2
    Info:MAIN:Time 416, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 355, socks 2
    Info:MAIN:Time 417, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 356, socks 2
    Info:MAIN:Time 418, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 357, socks 2
    Info:MAIN:Time 419, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 358, socks 2
    sta:rssi=-62,ssid=twtest1,bssid=44:d9:e7:59:f4:2a ,channel=1,cipher_type:MIXED
    Info:MAIN:Time 420, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 359, socks 2
    Info:MAIN:Time 421, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 360, socks 2
    Info:MAIN:wl_status 11
    Info:MAIN:Time 422, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 361, socks 2
    Info:MAIN:Time 423, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 362, socks 2
    Info:MAIN:Time 424, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 363, socks 2
    Info:MAIN:Time 425, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 364, socks 2
    Info:MAIN:Time 426, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 365, socks 2
    Info:MAIN:Time 427, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 366, socks 2
    Info:MAIN:Time 428, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 367, socks 2
    Info:MAIN:Time 429, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 368, socks 2
    sta:rssi=-63,ssid=twtest1,bssid=44:d9:e7:59:f4:2a ,channel=1,cipher_type:MIXED
    Info:MAIN:Time 430, free 103456, MQTT 0, bWifi 1, secondsWithNoPing 369, socks 2
    mqtt_pass demo@2018
    mqtt_clientID obk8C000000
    Info:MAIN:Time 431, free 103248, MQTT 0, bWifi 1, secondsWithNoPing 370, socks 2
    Info:MQTT:mqtt_subscribed to obk8C000000/+/set
    Info:MQTT:mqtt_subscribed to cmnd/obk8C000000/+
    Info:MQTT:MQTT client "obk8C000000" request cb: err 0
    Info:MAIN:Time 432, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 371, socks 2
    Info:MAIN:Time 433, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 372, socks 2
    Info:MAIN:Time 434, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 373, socks 2
    Info:MAIN:Time 435, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 374, socks 2
    Info:MAIN:Time 436, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 375, socks 2
    Info:MAIN:Time 437, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 376, socks 2
    Info:MAIN:Time 438, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 377, socks 2
    Info:MAIN:Time 439, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 378, socks 2
    sta:rssi=-64,ssid=twtest1,bssid=44:d9:e7:59:f4:2a ,channel=1,cipher_type:MIXED
    Info:MAIN:Time 440, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 379, socks 2
    Info:MAIN:Time 441, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 380, socks 2
    Info:MAIN:Time 442, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 381, socks 2
    Info:MAIN:Time 443, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 382, socks 2
    Info:MAIN:Time 444, free 103456, MQTT 1, bWifi 1, secondsWithNoPing 383, socks 2
    thanks and regards
    Manikandan V
  • #8 20208219
    Rate: 12914
    Are you saying that the latest OBK build disconnects from your MQTT broker without any changes to our codebase?
    What kind of MQTT broker do you have?
  • #9 20208337
    manivalaguru1
    yes base code also connecting and disconnecting, i am using mosquitto non sql here is my credentials
    strcpy(g_cfg.mqtt_host, "3.6.105.29");
    strcpy(g_cfg.mqtt_userName, "twdemo");
    strcpy(g_cfg.mqtt_pass,"demo@2018"); can you check with your code and get back to me
    thanks and regards
  • #10 20209934
    manivalaguru1
    can you able to recreate the issue??
  • #11 20211558
    Rate: 12914
    I have never used this particular MQTT broker in the past. Can you post an URL where to download that one?
    Also, from the logs I see that your MAC address looks like it was cleared with the flash erase. Can you try changing your device MAC to something unique?
  • #12 20211625
    manivalaguru1
    1) sry broker name is MQTT.fx https://mqtt-fx.software.informer.com/
    2) i have changed my mac address now but how can i keep some things from being erased while doing ota or flash erase?
    3) and still i have n't fixed that mqtt issue
    thanks and regards
    manikandan v
  • #13 20221885
    manivalaguru1
    have you got time to check that mqtt issue?
  • #14 20549263
    Rate: 12914
    The MQTT library we are using, the one from LWIP, was updated few months ago to latest version. Futhermore some threading fixes were applied to increase the stability. Does the problem still happen with latest OpenBeken?
The discussion revolves around maintaining a stable MQTT connection on the WBSL board using the OpenBK7231T SDK. The user reports frequent disconnections every 60 seconds despite modifications made to support a custom MQTT broker. Responses from the community suggest examining the modifications made to the SDK, particularly regarding the frequency of MQTT publish calls, and testing with the original SDK codebase. The user has added BLE functionality and created a pull request for further assistance. The MQTT broker in use is Mosquitto, and the user is advised to check the latest OpenBeken updates for potential fixes. Issues with MAC address clearing during OTA updates are also raised.
TL;DR: Seeing MQTT drop every ~60 seconds on a WBSL/OpenBK7231T? The log shows keep_alive 30 s; "MQTT might disconnect if you are... doing lots of publishes very often." [Elektroda, p.kaczmarek2, post #20200353]
Why it matters: Stable MQTT keeps smart-light control responsive and prevents needless reconnect load on your broker.
Why does my WBSL/OpenBK7231T drop its MQTT connection every 60 seconds?
Two common triggers are broker-side idle timeouts and publishing too frequently. The maintainer warned that excessive publishes can force disconnections. If you modified the SDK, ensure you do not publish every frame. Align keep_alive with your broker, and test with a clean build to confirm. [Elektroda, p.kaczmarek2, post #20200353]
Should I upgrade to the latest OpenBeken to fix MQTT drops?
Yes. The project refreshed its LWIP MQTT library and added threading fixes to improve stability. Update your device to the latest OpenBeken, then retest against your broker. This step has resolved similar stability complaints. [Elektroda, p.kaczmarek2, post #20549263]
What does "Disconnected, reason: 256" mean in OpenBeken logs?
It is the disconnect callback reporting a closed MQTT/TCP session. In the shared trace, the message appears right at the minute mark. Use it to correlate with keep_alive, Wi‑Fi status, and publish timing in your diagnostics. [Elektroda, manivalaguru1, post #20208083]
What keep-alive should I set for my broker?
OpenBeken shows keep_alive 30 seconds during connect. If your broker drops near 60 seconds, 30 seconds is suitable. Ensure your device sends traffic within that window. Confirm the negotiated keep_alive in your log line before tuning further. [Elektroda, manivalaguru1, post #20199074]
Can publishing too often break MQTT on OpenBeken?
Yes. "MQTT might disconnect if you are... doing lots of publishes very often." Throttle telemetry and state updates. Avoid publishing every PWM frame or inside tight loops. Batch changes or debounce to prevent buffer overrun and broker throttling. [Elektroda, p.kaczmarek2, post #20200353]
How can I isolate whether my code or the broker is at fault?
Try the maintainer’s baseline test:
  1. Flash the latest OpenBeken build.
  2. Hardcode the provided JSON string and publish on a fixed interval (for example, 30 s).
  3. Observe whether disconnects repeat without your custom code. If drops persist, inspect broker timeouts. [Elektroda, p.kaczmarek2, post #20205949]
Do large SDK changes (BLE, new_mqtt edits) risk MQTT instability?
Yes. The maintainer flagged “really lots of changes,” including new_mqtt and user_main edits. Big diffs can alter timing and buffer usage, breaking compatibility. Start from a clean base and reintroduce features incrementally, verifying MQTT after each change. [Elektroda, p.kaczmarek2, post #20205949]
Can a duplicated or reset MAC address cause MQTT issues?
Yes. After a flash erase, the MAC can appear cleared. A duplicated MAC or clientId can confuse the broker and collapse sessions. Set a unique MAC, reboot, and retest. This edge case can mimic random disconnects. [Elektroda, p.kaczmarek2, post #20211558]
How can I prevent losing IDs or settings during OTA or flash erase?
Avoid mass erase when doing OTA updates. A full erase can reset the MAC and other identity fields. If this happens, assign a unique MAC again and restore configuration. Preserving identity prevents broker-side session clashes after updates. [Elektroda, p.kaczmarek2, post #20211558]
Which log fields should I watch to troubleshoot MQTT stability?
Track Time, MQTT status, and secondsWithNoPing. In one trace, disconnect occurred at Time 420 with secondsWithNoPing 359. Also note "Successfully connected", your topic subscriptions, and "Disconnected, reason: 256" to align events. These markers reveal timing and broker behavior. [Elektroda, manivalaguru1, post #20208083]
Does OpenBeken actually connect and subscribe before it drops?
Yes. The log shows “Successfully connected” and two topic subscriptions before the disconnect cycle. That confirms credentials and topic patterns worked. Focus on keep_alive, identity, and publish cadence next. [Elektroda, manivalaguru1, post #20208083]
How should I share my code so maintainers can help quickly?
Fork the main repository and open a pull request. A fork provides a clean Diff view for reviewers. Avoid fresh uploads without history. This workflow speeds analysis and feedback on your changes. [Elektroda, p.kaczmarek2, post #20200854]
