Smart socket for charging PV equipment - features required, models, brands
cynamonik 690 2
  • Recommended smart socket features for PV charging setup
    #1 20828775
    cynamonik
    Rate: 143
    With a PV installation when there is sunshine and no one to connect the devices I would like to charge in:
    point A: powerbank, laptop, mobile phone, soon a bicycle
    and in
    point B an electric scooter with a Li-Ion 32 Ah/62 V battery (8A charger which gives an energy consumption of approx 1600-1800 W)
    A and B are about 20-30 metres apart.
    Essential functions:
    1 memory of settings after power loss
    2 return to last state after event as in point 1 after power loss or loss and return of wi-fi signal
    3 good wi-fi router, e.g. mikrotik (some brand supposedly has one)
    4 a timer
    5 monitoring of instantaneous energy consumption, control via an app of several such sockets
    6 direct wi-fi connection to the router
    WANTED:
    7 good google tyres as to the application
    8 Gosund has an option related to energy consumption, if some there set limit is exceeded it will perform some action
    I have found several companies: Settki, Hama, Gosund, Nous, LDNIO, Model and a huge !
    What do you recommend and what else to look out for ?
  • Gosund SP111 and PF161 power-loss behavior
    #2 20828869
    freebsd
    Help: 766
    Rate: 2034
    cynamonik wrote:
    1 setting memory after power loss
    Gosound SP111 remembers the state (on/off) and restores it when power returns.
    PF161 - the only model designation, no brand - has the option of setting the relay state in the settings directly. Just a note, I'm using the ZigBEE version and can only hope it's the same in the WiFi version.
    cynamonik wrote:
    8 Gosund has an option related to power consumption, if some preset limit is exceeded it will perform some action
    Gosound SP111 and PF161 have such options.
    cynamonik wrote:
    2 self-reboot after an event as in point 1 and return of wi-fi signal
    I have not observed such behaviour in ZigBee devices in use. I think that a momentary loss of communication should not even cause a spontaneous reboot.
    Maybe in addition to the smart home socket you would be interested in smart home relays? You then have NC and NO outputs.
  • #3 20829941
    cynamonik
    Rate: 143
    Thanks
    I didn't write about the relationship of communication loss > restart... although this is also a possible and undesirable scenario.
    I will correct point 2 in a moment so that it is unambiguous.
    With regard to relays, I would prefer a quick and tool-free possibility of placing a socket in any contact.
