[Solved] ESP8266 D1 mini from Tasmota fails to connect to WiFi when GPIO is connected
opaaa 1179 3
  • #1 20871069
    opaaa
    Level 4  
    Rate: 32
    ESP8266 on D1 mini board with tasmot uploaded.
    I have configured GPIO outputs: 0,2,4,5 as PWM, after physically connecting GPIO 2 to the transistor gate the chip does not connect to WiFi. What could be wrong? I am very much asking for help.
  • #2 20871095
  • #3 20871129
    inot
    Help: 449
    Rate: 818
    The GPIO 2 input at the time of reset should have level H (realised via resistor R11 on the board). If the transistor gate is polarised via an additional resistor with GND, this situation is not guaranteed.
  • #4 20871363
    opaaa
    Level 4  
    Rate: 32
    As it turned out GPIO2 is TXD1. I connected this transistor under GPIO13 and it worked.
