[Solved] Temperature difference on the Windy MTO 100B sensor vs. reality
AdameSzz 1674 1
  • External sensor likely needs calibration or better placement
    #1 20893044
    AdameSzz
    Level 4  
    Rate: 15
    Hi. I recently bought a Windy Weather Station MTO 100B with one external sensor. I don't know why the external sensor shows a different temperature than it actually is. E.g. on my phone it shows me that the temperature is -3 degrees and the weather station shows that it is 0 degrees outside and will not go lower. I have read in the reviews that it works for everyone without any problems. I live in a block of flats on the second floor and the outside sensor is fixed to the wall. I may have set the sensor wrong. Nowhere in the instructions did it say how to set up or calibrate the sensor. Thank you in advance for your answers.
  • #2 21004828
    AdameSzz
    Level 4  
    Rate: 15
    Replacing the external sensor helped
