WiFi-controlled four-slot USB power strip Woox R4027 connection problem
rekoba123 783 1
  • Need to verify pairing mode button behavior
    #1 21009000
    rekoba123
    Hi, I bought a Woox R4027 WiFi controlled four slot USB power strip, I have a router that transmits in 5GHz and 2.4 band, I have split both and the power strip is invisible to the phone/app. I have read that you need to pair the device with your phone and to do this you need to hold down the squeeze button on the strip for about 5s which will start flashing, unfortunately it does not flash. I am a layman in electronic/electrical matters, please help how to connect this to your phone....
  • Clarifying LED and relay behavior during pairing
    #2 21009938
    Rate: 12942
    Hello, is this information about the button from the instructions of the strip? Pairing methods differ from device to device.
    We have a topic about this strip:
    https://www.elektroda.pl/rtvforum/topic4036447.html#20964495
    Connect it to the power supply and try again, it should work if you follow the instructions.
    Does the LED light up all the time or is it off? Does pressing the button switch the relays?
