[KNX] Is it worth investing in KNX for the smart home? Alternatives?
Sourander1 1884 2
  • KNX cost concerns and alternative smart home architectures
    #1 21046784
    Sourander1
    Hello esteemed forumers. I was once part of a large smart home project based on the KNX standard. Most of the components were from Gira. The system was connected to SSWiN, KD, Advisor Master UTC alarm (the contacts in the windows turned off the heating) and even a 120kW generator and much more. The builder didn't reckon on the cost as he was fabulously wealthy. My question is: how do you do a smart home in practice? Because KNX is terribly expensive. What systems do you do it on? Is it a bus system or do you download everything to the switchboard? How do you configure because the ETS for KNX is probably something around PLN2k. Visualisation server PLN5k. I am looking forward to the factual answers.
  • #2 21097497
    Roeller
    Take a look at the forum at roelbroersma.nl, you can run a visualization server on your Synology or a VM. Some people cracked it ;) There are also cracked ETS versions around...
  • #3 21924798
    domsat
    Help: 47
    Rate: 188
    I’m revisiting this topic – I have a design for a single-family house with a KNX-based home automation system. I intend to explain to the client why such a solution makes no sense. Should I suggest Ampio, Nexwell or Grenton instead? Simple home automation can be achieved using bistable relays, Tuya and Supla controllers, etc. It’s cheaper and easier to maintain in the future.
