Roller shutter control Simon 82 Detail - how do I separate the buttons for two roller shutters?
kasper_7 864 0
  • Suggesting Supla and bistable relay options for shutters
    #1 21100835
    kasper_7
    I have such an unusual problem with a switch for roller shutters.
    I have two roller shutters in the living room, the installation was prepared for two keys separately, And for this three light keys, in a 5-fold frame. However, we chose the simon 82 detail series, which does not have a 5gang frame. So I re-arranged the wires and removed one box, unfortunately I couldn't re-arrange the lights any further as they are double staircase, so it fell to the roller shutters to have two in one box. I have the motors overloaded so they don't jump when getting to the end and work normally. But I would like to lower them separately because depending on where the sun is glaring. Either one window or the other. Simon 82 of course doesn't offer double blind buttons only single ones. I came up with the idea that I would install the supla controllers and then the button would give a signal to the two controllers at the same time, and from the phone I could control them separately. But I'm still trying to figure out how to split this button because it's always handy. Are there any other supla controllers that get not two up-down signals but one. And the controller getting a pulse would work once in one direction and once in the other? I'm also thinking of throwing in some bistable controllers in addition to the supple ones, so that I can control the bistable one first, and the bistable one will control the supple one. Only I don't know how it will behave when I want to lower it to half or 3/4, because logically, if the bistable gets an impulse it will hold it and the supla will lower the roller shutter, if it gets a second impulse it will switch to the other contact and the roller shutter will go up, i.e. from the key position there will be no option to interrupt lowering or raising. Does anyone have any other better ideas on how to solve this? The boxes are two pockets also I have room to fit this under the keys.
