How do I regain access to my OpenBeken device after changing my router?
Robgie 1284 5
  • Need alternative recovery methods for OpenBeken access
    #1 21102384
    Robgie
    Help: 31
    Rate: 16
    I have several devices on OpenBeken and I recently changed my router which changed my entire network configuration.
    I have recovered all devices except one. I can see them by scanning the IP but when I want to log on there is a system info that the connection was rejected.
    I also tried the power trick 5 times and it did not put up a hotspot.
    Is there any other trick to get on it?
    There is still the option of programming via cable but I would leave that as the last option. It is an aftermarket chip and I am in no hurry to remove it.
  • #2 21102400
    Rate: 12795
    What exactly does system info mean? Show a screenshot. Is it about the HTTP level message or that you have enabled password authentication on the device?
  • #3 21102522
    Robgie
    Help: 31
    Rate: 16
    This is the info from the browser after trying to connect after typing in the IP address. "This site is unreachable" and underneath "The server 192.168.xxx.xxx has rejected the connection". I have no connection to the webserver, i.e. I do not see any screen associated with it.
  • #4 21102534
    Rate: 12795
    Since you changed the router, how does the device connect to the new one? Did you keep the password and SSID the same?
    Switch the device off, wait a bit (to let the capacitors discharge) and switch it on again.
    And does the Web App on it work? Try the address (change the IP to your own):
    http://192.168.0.163/app?
  • 5-power-cycle reset restored OpenBeken AP mode
    #5 21102931
    Robgie
    Help: 31
    Rate: 16
    When I added the new router I managed to connect once and changed the login data to the new one, maybe I made a mistake there. the strange thing is that the iP scanner saw the device on the new address. Since then I have not been able to connect. app? also did not work.
    What did work was that I waited for about 2 minutes after switching off and then powered on 5 times and it came up as an AP.
    So I entered the data again and now I can see it and it works fine.
    Thanks for your help.
    OpenBeken device list and support link
    #6 21102934
    Rate: 12795
    So capacitors.... happens. It can be illusory. In any case, it's good that it works. If you have any other questions, set up a separate topic and you can send me a link on PW then I'll find it quicker.
    Also, remember that we collect information about devices, here:
    If you have something not on this list, you can also create a topic with a template and description of the device.
