Why Doesnt OpenBeken Fall Back to AP Mode Like Tasmota Devices?
rickwookie 3723 6
  • Questioning why OpenBeken lacks AP fallback mode
    #1 21242531
    rickwookie
    With all my Tasmota devices, whenever they lose connection for whatever reason to the WiFi network, then immediately fall back to AP mode where they broadcast their own open WiFi. This is super useful as it means if you ever change your WiFi settings or move the device to another location, you can easily regain access to it to update the stored WiFi credentials. Additionally, if the "expected" WiFi SSID reappears at any point while the device has fallen back to its AP mode, it immediately rejoins.
    Is there any good reason why OpenBeken doesn't behave the same way?
    Open AP fallback avoided for security reasons
    #2 21242643
    max4elektroda
    Help: 49
    Rate: 189
    There is some discussion about this in issue 1246.
    The AP mode is just an open one. So if your WiFi goes down, and the device starts an open AP, everybody around could easily "hijack" your device.
    I would agree this might be a good idea if the device becomes a secured AP, but this is not possible atm (though there is a first attempt for a WPA2 AP in PR#1256.)
    If you really need this, you might be able to do something similar with some commands (calling the command "OpenAP" on a condition with "waitFor").
    And there is always the possibility to force safe mode after 5 unsuccessful boots (restarting the device 5 times after a few seconds).
  • #3 21242951
    Rate: 12809
    Isn't such behaviour a serious security threat? You can enable "Safe mode" in OBK by doing 5 power off/on cycles which is a bit more secure than just disabling WiFi...
  • Safe mode may have caused the reset behavior
    #4 21243128
    rickwookie
    Erm, not much more than being able to just find the device via a network scan and access its web interface anyway.
    And presumably if security was of any concern, then:
    "Web Authentication
    Enabling web authentication will protect this web interface and API using basic HTTP authentication."...
    Which presumably means that anyone accessing it when it reverts to Open WiFi would be presented with a password prompt before gaining access. Or does safe mode bypass the web authentication too?
    I'll have to have a look at safe mode then. Sort of explains what was happening to my devices earlier when they appeared to have just "reset themselves" after the first reboot after initial setup and were no longer responding to buttons. Not sure why they went into safe mode if they did, because it was only one reboot and not five. What's the best way to exit safe mode if you've triggered it by mistake? Is it simply to re-enter the correct WiFi credentials, or is there another way, like just select restart from the web interface?
  • Safe mode starts as AP without resetting settings
    #5 21243191
    max4elektroda
    Help: 49
    Rate: 189
    I see your point, but there's quite a difference if someone who is "trusted" enough to have access to your WiFi can mess with the device or everyone around can access the device...
    Added after 5 [minutes]:
    No, it doesn't (even if there is a flag to do so, with the attribute "not recommended").
    That's not necessary, safe mode won't reset the settings, it's just starting without most of the drivers and as AP instead of STA. You can then do possible changes, to fix whatever lead to safe mode and then restart in "normal mode".
  • Crash loops or brownouts trigger safe mode AP
    #6 21243221
    Rate: 12809
    In my country we have flats with many families living (like on separate floor levels) and they can see each other WiFi networks, but no one knows the password of the neighbours.
    If you configure something in a way that it crashes, it will try to boot 5 times and revert to safe mode on it's own. Also, if you power WiFi module from unstable power supply, or directly from 3.3V pin of some cheap USB to UART converter, it may also BOR and reboot and revert to AP.
  • Unstable power supply can trigger AP fallback
    #7 21243889
    rickwookie
    So the web authentication is the solution then surely.
    If you configure something in a way that it crashes, it will try to boot 5 times and revert to safe mode on its own. Also, if you power WiFi module from unstable power supply, or directly from 3.3V pin of some cheap USB to UART converter, it may also BOR and reboot and revert to AP.
    Could have been the cheap board power design in both cases. I paid PLN2.37 total including tax to get it shipped from China after all! One time the board was powered from an 8 V a.c. doorbell transformer, and the other time via the 5 V d.c. microUSB port direct from my old laptop.
✨ The discussion centers on the behavior of OpenBeken devices compared to Tasmota devices regarding their fallback to Access Point (AP) mode when losing WiFi connection. Users express concerns about security risks associated with OpenBeken's open AP mode, which could allow unauthorized access. Suggestions include implementing a secured AP mode, which is currently under development. Users also discuss the functionality of "Safe mode," which can be triggered after multiple unsuccessful boots, allowing for troubleshooting without resetting settings. The conversation highlights the importance of web authentication for securing device access and notes potential issues with power supply stability affecting device performance.
