Ariston Genus One Gas Boiler Not Connecting to New WiFi Network
ajdahabjanic 6345 5
  • #1 21208988
    ajdahabjanic
    Hi! I have a gas boiler Ariston Genus One. And I have a new WiFi. The boiler does not want to connect to the new WiFi. Has anyone had similar problems?
  • #2 21209147
    Rate: 12913
    Have you tried checking the manual to see the WiFi pair procedure?
    I've checked web for some manuals, maybe that one can help?
    G.C.N.: 47-116-93 (24 kW)
    G.C.N.: 47-116-94 (30 kW)
    G.C.N.: 47-116-95 (35 kW)
    • GenusOnenet24-Plus - User Manual.pdf (1.66 MB) You must be logged in to download this attachment.
  • #3 21209226
    ajdahabjanic
    >>21209147 >>21209147
    Thank you soooo much! I was looking at my manual at home and it only had info about first WiFi set up. I had to change WiFi setting from private IP address to log into the panel of a router. Thanks again!
  • #4 21360102
  • #5 21360481
    madyd
    Help: 34
    Rate: 91
    An ariston cube s net thermostat is connected to the boiler?
  • #6 21362784
    ajdahabjanic
    >>21360102 I followed the instructions from the attachment manual that has been uploaded here on 30 august 2024. It takes a bit of work if I remember correct, but it's not that hard to fix it, just follow what the manual says.
