Moes 1 Gang Switch: How to Disable LED Indicator When Light is Off?
maikschmidt790 885 1
  • Moes switch LED stays dim when relay is off
    #1 21278571
    maikschmidt790
    I'm using a Moes 1 Gang Switch with RF, same model as https://www.elektroda.com/rtvforum/topic3971440.html
    is it possible to turn off the led of the switch when the light is off?
    I have one other Switch where this is the default with the manufacturer firmware.
    I tried different combinations of tuyaMcu_defWiFiState in the autoexec.bat, but none of it changes the led.
    The led is flashing till it is connected to the wifi and mqtt.
    After that it is bright when the relay is on and low when off.
    But never really off like I would like it.
  • #2 21279523
    ferbulous
    Help: 8
    Rate: 56
    Instead of wifi_led, can you just assign the pin as LED 1 only? Or don't assign anything to the pin
