[Solved] OpenBeken/Tasmota: How do I (set) to remember the last relay status after a power failure?
Adam-T 855 2
  • Need relay power-on state to restore last status
    #1 21291923
    Adam-T
    Help: 834
    Rate: 1095
    Question regarding OpenBeken (and I guess Tasmot): how to set the relay status to "remember last status". There is an option in smart sockets that, when the voltage is switched off and when it comes back on, sets the relay to the same position from before it was switched off.
    I have uploaded myself in a couple of OpenBeken modules and just when the power comes back on, the relay is always on off.
    Rate: 12794
    In OpenBeken, as you have already set the relay role for a pin (Rel), you can set it's initial state in the options: 0 (off), 1 (on) or -1 (remember last state):
    OpenBeken/Tasmota: How do I (set) to remember the last relay status after a power failure? .
  • #3 21292506
    Adam-T
    Help: 834
    Rate: 1095
    Thank you very much, everything works as it should.
