[Solved] Maintaining Relay State Post OTA Firmware Update on BK7231N Devices
Automauto 1701 4
  • #1 20899147
    Automauto
    I have a few BK7231N power plugs that I have flashed with OpenBeken.
    When I update their firmware OTA, they reboot and their relay is OFF.
    Is it possible to have the relay be ON by default after a reboot?
    Ideally, they would not switch OFF at all during a firmware update.
    Thanks for any help with this.
    Startup command or autoexec.bat to restore relay state
    #2 20899256
    Rate: 12914
    I think you can set this in Startup tab in settings:
    ChristmasT software settings interface for configuring pin start values.
    Alternatively, you can just enter a startup command or write autoexec.bat script with something like:
    setChannel 1 1
    or, if you prefer Tasmota syntax:
    POWER ON
    There will always be a little click when you reboot device, as it takes a short moment to start OBK after booting
  • #3 20899262
    Automauto
    Thanks!
    I just tried -1 as a value in Config Startup > Channel 0, and the switch powers on again after a firmware update.
    I'm guessing there is no way to keep the switch on during an update?
    I use some of these to monitor PC power use, and the restart causes issues :)
    Rate: 12914
    Well, why would you like to keep relay on during update? It's not that update is done very often....
    Still, depending on your use case, maybe it would be possible to make some kind of hardware mod to the device to open relay with a delay.
  • #5 20899274
    Automauto
    First reply was great and gave me some options to resolve this issue.
