Configuring OpenBK for AP Mode Reset While Retaining Device Settings
kaplanroger 987 1
  • OpenBK AP mode reset while keeping settings
    #1 21318051
    kaplanroger
    Is it possible to configure OpenBK but then reset the Wifi so that the next time it's powered up it goes into Access Point mode but keeps the config once the new wifi is set up?
    I want to flash and configure a device at home, and then install it in a different location with a different wifi setup.
    In Tasmota there are commands that clear just the wifi info but keep everything else, and the device defaults to AP mode with missing wifi info.
    AI: Could you specify the device model you are using with OpenBK?
    Treatlife DS03
    AI: What version of OpenBK are you currently using?
    Latest
  • #2 21320128
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    The way I do it is that I set up a hotspot on the data of my home network and, already on site, configure with my smartphone to the new target wifi network.
