[Solved] Can sockets from Aliexpress (WiFi + RF 433 MHz) replace ORNO OR-SH-1731?
GieKa 774 3
  • Need to verify whether 433 MHz sockets are receivers only
    #1 21374091
    GieKa
    Rate: 31
    Some time ago I bought such a socket set with remote control (433 MHz).
    https://www.orno.pl/pl/zestawy/318-zestaw-bez...-pilotem-3-1-wersja-schuko-5900378654728.html
    It is used to switch on the Christmas lights in the house. It works well only you have to remember to switch it on and off though. But recently I came across a socket like this.
    https://www.orno.pl/pl/gniazdo-centralne/325-...-fi-i-nadajnikiem-radiowym-5908254810589.html
    It can control the above-mentioned sockets (433 MHz) and has WiFi, so you can set and programme the on and off times. Only it costs PLN 120 and more. For this amount you can buy 4-5 Tuya wifi sockets on Aliexpress. And I started to look for a replacement there. I found something like this.
    https://pl.aliexpress.com/item/1005006909139702.html
    https://pl.aliexpress.com/item/1005004702512407.html
    Could these be replacements for this ORNO? They have RF 433 MHz only does this socket not work only as a receiver? Can you somehow make this out from the information there? Or does anyone know of a replacement?
  • #3 21374410
    GieKa
    Rate: 31
    I mean what do I have written there and where underneath?
  • #4 21565415
    GieKa
    Rate: 31
    I didn't mess around with cheap sockets from Aliespress but bought this from ORNO.
