[Solved] BL602 MagixHome RGB: Low Blue LED Glow Issue After Openbeken Flashing
Upright6771 558 1
  • Low blue glow on one BL602 strip after flashing
    #1 21381915
    Upright6771
    Level 4  
    I flashed 3 pieces of BL602 (MagixHome RGB) with OpenBeken. As far as I can see, they are all identical, but on one of the strips the blue part of the LED strip glows very low, if the strip is off. Is this a known problem, or can I set the zero point to 2% brightness, for example, so that the strip goes out sooner?
    I mean, that the problem is still there, after flashing OpenBeken. I haven't seen this problem with stock firmware.
  • #2 21383604
    Upright6771
    Level 4  
    Looks like that I have solved the problem by myself.
    The internal temperature of the CPU was at 80 degrees. After unplugging and plugging the power source, there is a short between GND and input. A new controller fixed the issue, so looks like that the controller is dead.
