Selection of DC voltage for distribution in the home (for home automation, routers, lighting)
marcingebus 582 3
  • 48V distribution with local DC-DC conversion
    #1 21390795
    marcingebus
    Rate: 31
    I am running an APC SMT 3000VA UPS at my place with 4 AGM 200Ah batteries. The total DC voltage will be 48V. The UPS is to power a fridge, some lighting, some server, an emergency socket for a laptop in case of an emergency connected to HomeOffice etc.... I plan to connect directly to the batteries of this UPS (behind appropriate fuses) and treat these batteries as a source of DC voltage to power various automation components based mainly on ESP - such a small 48V powerhouse. "Naked 48V" I will drop in on the PoE switch. I have a dilemma as to what voltage to accept to power the rest. Do I run wires to the various places in the house where I have (will have) ESP modules "bare 48V and locally use a StepDown from 48V to 3.3/5V (but there are not many of these at mayfrients), or do I make a central transition to 12V or 24V DC (with some larger SteoDown) and distribute a lower voltage than 48V? Or maybe ditch the direct connection to the battery and rather use a 230V->12/24/48DC power supply?
    The main DC applications are to power:
    - Internet router/switches (6 devices scattered around the house)
    - various sensors, motion/presence/temperature/humidity soldered on ESP (Dallas, SHT35, rainwater level measurement etc...)
    - monostable switches for the main lighting to control the ESP+relays (plus some voltage divider at the ESPs themselves)
    - a couple of LEDs on GU10 or similar (night lighting/"quasi-emergency" = to operate when there is some kind of mains failure.
    Question: what voltage to adopt for distribution and what are the advantages and disadvantages of adopting this particular solution?
    P.S..
    I have a small meter that measures the voltage on each battery and writes to ESPHom, so I'll have a preview of how the voltage on the batteries behaves, and if their capacity doesn't bear up to a prolonged fade, I'll add some apparatus that disconnects from the batteries to keep them from discharging below 10.5V/battery.
  • #2 21390817
    kindlar
    Help: 919
    Rate: 1622
    And can't you isolate the circuits where the emergency power produced by the "inverter" will appear in the event of a mains failure instead of combining with DC?
  • Isolating backup circuits while keeping sensor dc supply
    #3 21390851
    marcingebus
    Rate: 31
    Of course you can but I still need some DC voltage to power the various sensors. It seems that the StepDown is a smaller device (also probably cheaper) than the HiLink power supply at each ESPeek.
    The question is what voltage to adopt and why that would be best. ;-) .
  • 24 V battery system with 12 V distribution
    #4 21390867
    margas60
    I have a small OFF-grid in the block of flats, which is why I did it like this: from 24V LIFEPO4 160Ah batteries, a car converter to 12V 20A supplies all the lighting [bulbs and LED strips], a controller with a timer controlling 4 sockets, powering all the automation, modem, router, two Synology servers, charging phones or other devices. The conversion from DC to 230 AC is fraught with too many losses, which is why I only feed through the inverter what I cannot supply with 24 V or 12V at low currents.
