[Solved] Installing Home Assistant Firmware on Tuya IR Blaster BK7231M
taaznoh 588 1
  • Provided BK7231M encryption key and firmware details
    #1 21419301
    taaznoh
    Hey folks,
    The log says to post a newly discovered encryption key to here so:
    Encryption key: 510fb093 a3cbeadc 5993a17e c7adeb03
    It's from a Tuya IR Blaster with a BK7231M.
    What would I need to do to successfully install a home assistant compatible firmware?
    Thanks a bunch for all the work you already did!
    Jan
    AI: Could you specify which home assistant compatible firmware you are planning to install on your Tuya IR Blaster?
    OpenBK7231M_QIO_1.18.31.bin
    AI: What is the current firmware version on your Tuya IR Blaster?
    Original idk
  • #2 21419307
    taaznoh
    Seems I misread the chip and it is indeed an N not M. Sorry pals.
