Samsung TV dims for a second after running electric blind - power interference?
Bodkowy 624 3
  • Check for voltage sag or loose mains connection
    #1 21527639
    Bodkowy
    Rate: 46
    problem:
    After switching on the roller shutter with the key switch, the TV dims for 1 second (black screen).
    Tv connected to cable TV decoder with hdmi cable.
    I don't know how the installation is made as it is a developer's flat. However, the sockets are close to the roller blinds, so it is highly likely that the roller blinds are powered from this circuit.
    The problem arose recently - after changing the TV.
    On the old one it was rather ok or I did not notice this phenomenon.
    Similar topic to this [url= https://www.elektroda.pl/rtvforum/topic3511568.html] .
    Unfortunately the author did not share the solution.
    I have read a lot about the hdmi cable but is this really a good lead?
    I am targeting a faulty connector.
    What do you guys suggest to check?
    Greetings
  • #2 21527663
    slavik78
    Help: 65
    Rate: 100
    >>21527639 .
    If you disconnect this set-top box from the TV (unplugging the HDMI cable) does the TV also dim when you switch on the blinds, the same when you unplug this set-top box from the mains?
  • #3 21624017
    szrajbendorf
    I have the same problem with my LG OLED TV. Before the LG I had a Philips LCD and there was no problem. The rest of the setup and wiring has not changed with the change of TV.
    I have KNX controlled roller shutters that close automatically at a certain time. And it is at this point that the TV dims.
  • #4 21634392
    Bodkowy
    Rate: 46
    I won't answer you, that's what was happening at my friend's house. I gave her hints on what to check but apparently she can live with it and has not done anything about it further.
