OpenBeken Syslog Support for UDP514 Logging Without MQTT Integration
cijoml 717 6
  • #1 21538788
    cijoml
    I would like use same setup as in Tasmota for logging with OpenBeken. With Tasmota you can disable MQTT and use standard syslog for messages i.e. UDP/514 port.
    Is this considered to be implemented? Thank you in advance.
  • #3 21541912
    cijoml
    hi there,
    since Loxone crippled their MQTT implementation for only 1200 events/day it is useless. Thus we all use syslog parsing as backward channel. For example if you switch on/off wifi socket manually by button to correctly update within Loxone. I also use it for energy metering informations back to Loxone.
  • #4 21559053
    cijoml
    @divadiow or @p.kaczmarek2 would you consider sending syslog as backward channel? There are a lot of Loxone users like me out there :)
  • #5 21559073
    Help: 449
    Rate: 918
    Hi. I appreciate the tag but I have no real C development skills to be of any use with this 😁
  • #6 21788447
    cijoml
    @p.kaczmarek2 are there any news for this request? I still lack back channel to my Loxone miniserver :( Loxone still does not fixed their MQTT support.
  • #7 21839646
    cijoml
    @p.kaczmarek2 any plans implementing UDP syslog same as Tasmota does? I really need backward channel to LOXONE
The discussion asks whether OpenBeken can support Tasmota-like syslog logging over UDP port 514 without MQTT integration. The use case is a backward channel for Loxone installations, where MQTT is limited or unusable, so syslog parsing is needed to report manual switch actions and energy metering updates back to the controller. A forum link is shared, the feature is requested again multiple times, and no implementation or development commitment is confirmed.
