How to check the electromagnetic relay? One way
tomybb 18675 37
  • Tests a small 12V electromagnetic relay in a car module that appeared healthy on a multimeter but was actually faulty.
  • Checks the relay by loading its output with a receiver, comparing a digital multimeter, an analog meter, a LED with resistor, and a 12V bulb.
  • At around 12V, only the incandescent lamp exposed the fault: output voltage dropped, the bulb dimmed, and full voltage never reached the load.
  • The takeaway is that relay contacts should be tested under load, because meters and LEDs can miss contact damage.
  • The author warns that the load must be appropriate: too high can cause harm, too low may hide the defect, and 230V tests are unsafe.
  • Oxidized relay contacts fail at low current
    #31 21548854
    noel200
    Help: 36
    Rate: 815
    cranky wrote:
    Well, those very contacts had oxidised enough (because they probably weren't dusty) that they weren't supplying voltage. The flowing current was burning through/piercing the oxidised layer on the contacts. And these contacts, through which the current flowed close to zero - stopped contacting.
    I've probably had about a dozen cases like this too. If the relay switched a very small current it stops conducting after a few years. If you apply a higher load and switch the contact on a ball of times, it somehow clears the contacts and the relay continues to work.
  • #32 21548876
    Ryszard49
    Help: 312
    Rate: 1011
    noel200 wrote:
    I have also had probably a dozen cases like this. If the relay switched a very small current, it stops conducting after a few years.
    Simple solution, use relays with gold plated contacts.
  • #33 21548887
    noel200
    Help: 36
    Rate: 815
    I was writing about industrial relpols and omrons for over 100PLN a piece. In DS there is a description that the contacts are gold plated.
  • #34 21549512
    cranky
    Level 30  
    Help: 70
    Rate: 415
    Ryszard49 wrote:
    use relays with gold-plated contacts.
    Written by Richard49 "Gold plating-hot stamping" :) .
    (Joke, not malice, I know you don't want to gild the relays with service)
  • #35 21549550
    Ryszard49
    Help: 312
    Rate: 1011
    cranky wrote:
    Written by Richard49 "Gilding-hot stamping"
    Hot stamping is a form of print enhancement.
  • #36 21549623
    cranky
    Level 30  
    Help: 70
    Rate: 415
    >>21549550 .
    I know, it was just so verbally cool to put together.
    And the best contacts in relays tend to be platinum. I had one that ran for years under highly exaggerated currents and cleaned every 2 years it lasted forever.
    I also remember platinum being stolen in lifts.
  • #37 21560251
    jarekgol
    Level 40  
    Help: 645
    Rate: 1150
    In what better data sheets there is a minimum current / self-cleaning current for the contacts.
  • Tap test reveals intermittent relay conduction
    #38 21571907
    George54351
    If there is a known problem that some relay is malfunctioning then by slightly hitting it with a screwdriver it may revealed when is in conducting state.Also if the relays of the circuit are commercially available in a reasonable cost then is a good option to replace them all at once.Especially in car pcb's if the problem is common then probably there are available spare parts,as relays for the doors locks for example.This goes to relative small and low cost relays found in commercial pcb's and easy available.
The discussion focuses on methods to check electromagnetic relays, emphasizing the limitations of using an ohmmeter alone due to its low test current, which may not reveal contact faults such as corrosion, mechanical damage, or oxidation that manifest under load. Measuring contact resistance with an ohmmeter can indicate continuity but often fails to detect issues that appear only at higher currents. Testing relays under load using incandescent bulbs or specialized testers (e.g., Testboy) provides a more reliable diagnosis by simulating real operating conditions and revealing contact degradation through voltage drop or flickering. Visual inspection of contacts, especially in relays with transparent housings, is also important. The coil resistance should be measured first to confirm coil integrity. Some relays have gold or platinum-plated contacts to reduce oxidation and improve longevity. Thermal imaging is recommended for contactors and high-current relays to detect overheating contacts. The discussion also notes that relay failures can be intermittent and that testing in the actual circuit with appropriate load current is often the most effective method. The importance of understanding relay specifications, such as minimum or self-cleaning current, is highlighted for proper testing and maintenance.
