Microprojects - A simple (stereo) bar-LED driven driving indicator.
398216 Usunięty 4698 85
  • Stereo bar-LED driving indicator module uses two LM3915 channels to drive 10-segment green-yellow-red LED posts.
  • An LM741 with a 1N4148 quasi-ideal rectifier converts audio to DC, and the PCB is made by thermal-transfer etching with goldpin-mounted display boards.
  • The finished module measures 38mm wide, 35mm high, and about 55mm deep, and it runs from 12V.
  • Its attack and decay suit level metering: the bar reaches full indication in about one-tenth of the time it takes all LEDs to go out.
  • The 12mm gap between driver boards leaves little clearance, so capacitors must be low-profile, and bridge-output amplifiers require separate supply and signal grounds.
  • #31 21548132
    acctr
    Help: 389
    Rate: 2021
    sq3evp wrote:
    Mechanical in the sense of artificial, too accurate for the real world.
    Mechanical is what the C64 sounded like, there's an appropriate term for what you're writing about - CD sound is sterile.
  • #32 21548204
    398216 Usunięty
    Help: 3925
    Rate: 9303
    Hehehe...how it is through inaccurate presentation of the subject that wrong conclusions can be drawn.... :)
    Nothing to it,
    Personally, I would describe the sound of a CD as rather sterile - mechanical (in my opinion) doesn't really fit here; I've seen a bit of different mechanisms in my life and I've never encountered a "pure" mechanism - without its own noises such as rasps, squeaks, hums .... perhaps that's why I misunderstood the meaning. And the fact that a black record sounds better is a long known fact; Anything that is analogue from start to finish will be more pleasing to our hearing. After all, we have encountered this kind of sound for thousands of years.
  • #33 21548225
    acctr
    Help: 389
    Rate: 2021
    Knowably, primitive man sitting safely in a cave heard muffled sounds from outside, this appealed to him so he survived. Another species preferred to listen to dinosaurs without distortion and ended up as a fossil :D .
  • #34 21548234
    vodiczka
    Help: 1185
    Rate: 4301
    398216 Usunięty wrote:
    And the fact that the black plate sounds better is a long known fact;
    Better than what? If better from what used to be before black vinyl ie black shellac then you are right.
  • #35 21548255
    efi222
    Help: 12
    Rate: 1205
    CD/vinyl, this is a topic without end....
    Here the question would have to be asked:
    Which sounds more "real"?
    In the sense of a comparison to the source.
  • #36 21548819
    sq3evp
    Help: 219
    Rate: 871
    efi222 wrote:
    CD/vinyl, is a topic without end....
    Oh Lord, this is nominally heresy - there are people who use audio equipment for several tens of thousands of zloty to listen to MP3s.
    Nothing to discourse about for them....
  • #37 21549081
    398216 Usunięty
    Help: 3925
    Rate: 9303
    vodiczka wrote:
    From what?
    From the CD, of course. And I don't mean pseudo vinyl pressed from digital recordings in addition with compression cutting off all dynamics. And to answer another question; Better in terms of naturalness of sound. The difference between vinyl vs. CD is more or less like the difference between an original Van Gog piece and a copy on chalk paper. I have seen such and I must say it does not look good.
    Another thing is that today's society has degraded hearing compared to decades ago, for example.
    Ubiquitous broadcasts, and especially commercials, effectively limit the ability to distinguish what sounds good from those commercials; not only that, but I have even encountered the opinion that this sound, with flattened dynamics and artificially "beautified" by boosting the band's extremities (please do not confuse this with the operation of a loudness filter!), sounds ...NATURAL... :) Being told by the clique that black is white has the effect of making weaker individuals start to believe it. Just like with this "coup".
    It is not without reason that I wrote about the ready-made indicators from Aliexpress, which yes "twinkle" and at first glance even seem to be in line with the signal, while the truth comes out when a tuned generator is connected.
  • #38 21549110
    vodiczka
    Help: 1185
    Rate: 4301
    The difference between vinyl vs. CD is about the same as the difference between an original Van Gog work and a copy on chalk paper.
    You're conjuring, mate, because you're comparing the ways in which the original is abused and not the possibilities of vinyles and CDs as carriers and the signal converters that work with them. The possibilities of the latter are significantly greater, it's a pity they are not used in mass production. You listen to an original work in a philharmonic hall, not from loudspeakers or headphones.
  • #39 21549127
    efi222
    Help: 12
    Rate: 1205
    vodiczka wrote:
    An original work is listened to in a philharmonic hall and not from loudspeakers or headphones
    This is true. Because nothing has yet been invented here (and will probably remain so for a long time) that can bring this atmosphere into the home.
    But everyone is looking for a solution that is at least a substitute for this climate.
  • #40 21549156
    vodiczka
    Help: 1185
    Rate: 4301
    efi222 wrote:
    But everyone is looking for a solution,
    Of course, I am attached to vinyl records and phono cartridges but I do not consider CDs to be an inferior solution in terms of sound quality.
  • #41 21549193
    acctr
    Help: 389
    Rate: 2021
    vodiczka wrote:
    An original work is listened to in a philharmonic hall, not from loudspeakers or headphones.
    Including the snotting or coughing music lover sitting next to you or the sounds of trams passing by. There are no ideal conditions, so unfortunately in the real world you have to get to like the noise.
  • #42 21549197
    efi222
    Help: 12
    Rate: 1205
    There was a similar discussion on the forum recently.
    CDs yes. Provided they have not been affected by loudnes war. This problem does not apply to vinyl records, which, due to the playback technique, have not been "contaminated" by this affliction, or at least not to the same extent as CDs.
    Here you can check the DR value (dynamic range) for different record releases.
    https://dr.loudness-war.info/
  • #43 21549405
    acctr
    Help: 389
    Rate: 2021
    Akurat is not the fault of the playback technique but of the implementation of the recordings. CD itself has a huge advantage in dynamics over vinyl, i.e. 96 dB to a maximum of 40 dB.
  • #44 21549434
    efi222
    Help: 12
    Rate: 1205
    acctr wrote:
    The CD itself has a huge advantage in dynamics over vinyl,
    What do I care about the theoretical amount of dynamic range, if the engineer screws everything up to the max and the 96dB can be put in your shoes. I won't even mention the additional distortion...
    Quite a few records like this have been made. A friend of mine is looking for older CD releases for this reason.
  • #45 21549451
    acctr
    Help: 389
    Rate: 2021
    efi222 wrote:
    What do I care about the theoretical amount of dynamics if the realist screws everything up to the max and those 96dB can be put in your shoes.
    This is not theoretical dynamics but authentic/real/factual. What the realiser does is another tale and has nothing to do with the CD reading technique, but on his skill or the artist himself.
    Loudness war has already appeared on vinyl, e.g. The Beatles, what this has to do with a particular CD or vinyl medium you can't meaningfully explain.
  • #46 21549540
    sq3evp
    Help: 219
    Rate: 871
    efi222 wrote:
    What do I care about the theoretical amount of dynamic range, if the engineer screws everything up to the max and the 96dB can be put in your shoes. I won't even mention additional distortion....
    That's the thing - dynamics is just a parameter, and the realiser can mess it up.
  • #47 21549624
    efi222
    Help: 12
    Rate: 1205
    On vinyl such attempts (loudnes war) were sprady. Digital recording facilitated and resulted in some years in the widespread use of this procedure, until it led in extreme cases to a hopeless flattening of the sound with additional clipping that was a side effect of such processing.
    These discs sounded very bad, and we are talking here about the sound, not the parameters of the media.
    Black discs still have advocates of digitally unprocessed sound today.
    It is the same with the "shooting" of feature films.
    Despite widespread digitisation, half of film productions continue to be made on film stock, because the image from it is simply different (prettier, artistic). And there is no magic here.
  • #48 21549691
    vodiczka
    Help: 1185
    Rate: 4301
    acctr wrote:
    Including a snotty or coughing music lover sitting next to or the sounds of passing trams.
    An infected music lover is a random event and a shed in which a passing tram can be heard does not deserve to be called a philharmonic.
  • #49 21549798
    acctr
    Help: 389
    Rate: 2021
    vodiczka wrote:
    a building where you can hear a passing tram does not deserve to be called a philharmonic
    Trams can be heard, world-class artists want to play and people buy tickets that sometimes chairs have to be added :D .
  • #50 21549822
    vodiczka
    Help: 1185
    Rate: 4301
    acctr wrote:
    Trams can be heard,
    Enter address
  • #52 21549969
    398216 Usunięty
    Help: 3925
    Rate: 9303
    acctr wrote:
    This is not theoretical dynamics just authentic/real/factual. What the realiser does is a different tale and has nothing to do with the CD reading technique but on his skill or the artist himself.
    Correct. However, so what if the equipment itself has 98dB of noise isolation if the CD played back in it has a "flattened" dynamic range down to 80dB? Is it possible to speak of good quality sound reproduced in this way? You're right, the equipment is essential, but if the sound engineer is a d..b., even the best equipment won't change that.
    A'props to the coughing guy sitting next to you at the concert - I've heard a CD (black) where the sound was deliberately mixed with the hall sounds and it sounded really nice - listening to it you could get the impression of being a participant (live) in a concert; even when you closed your eyes you could hear the moment when the person in the row in front of you changed their position in the fort.
    In fact, I don't count such a recording of a concert as a mistake; it simply captures the full impression of the concert hall, including its imperfections. Another thing is that such a recording is best listened to on headphones, as it loses on speakers.
    However, when it comes to listening on loudspeakers, I agree that sterile recordings - recorded in a studio - sound best. This is because the imperfections of the room come into play and the sound is less sterile/artificial.
    Colleague acctr is right when he writes:
    The real world is what it is. We don't have the option of locking ourselves in an anechoic chamber with our equipment.
  • #53 21549979
    vodiczka
    Help: 1185
    Rate: 4301
    acctr wrote:
    Where is the tram going?
    Where does the filhamonia stand
  • #54 21549989
    tesla97
    Help: 22
    Rate: 156
    Normally (worked out by experience) the ironing time for me should be 4 minutes
    Only 4 minutes? At my place it was usually a minimum of 8-10 and larger PCBs are and 10-15min less is an empty laminate.
  • #55 21550001
    vodiczka
    Help: 1185
    Rate: 4301
    You're right, the equipment is the key, but if the sound engineer is a d..p., even the best equipment won't change that.
    So you're admitting that it's not about the differences between CD and vinyl but how the sound engineer will use them.
    However, so what if the equipment itself has 98dB of noise isolation if the record played back in it is of "flattened" dynamics to 80dB?
    This is still more than 30 dB of vinyl, at times 35 dB.
    The same is true for channel separation in stereo playback although in practice separation greater than 30 dB is not necessary.
    Let's not forget the big disadvantage of vinyl - deteriorating sound quality with the number of plays not to mention accidental scratching of the disc.
  • #56 21550007
    acctr
    Help: 389
    Rate: 2021
    vodiczka wrote:
    Where does filhamonia stand
    I'm not going to write it because I don't want to do black PR, especially after the way you specified.
  • #57 21550049
    vodiczka
    Help: 1185
    Rate: 4301
    acctr wrote:
    I'm not going to write that
    Don't be shy, google doesn't hide the truth
    23 February 2012 - The Baltic Opera's current venue is not the happiest. Sometimes during opera performances you can hear a tram passing by .
    16 mar 2023 Krakow Philharmonic. - In the current location, there are occasionally external chords during a concert associated with the passing of trams on lines 1, 2 or 8 .
  • #58 21550050
    acctr
    Help: 389
    Rate: 2021
    Now you know and you can go and see for yourself what I wrote about.
  • #59 21550058
    vodiczka
    Help: 1185
    Rate: 4301
    I believe, I will not go.
    The Lodz Philharmonic is better soundproofed and you can't hear a tram passing by on Narutowicza Street, even though it's going ''under your windows''.
  • #60 21550840
    398216 Usunięty
    Help: 3925
    Rate: 9303
    tesla97 wrote:
    only 4 minutes? With me it was usually a minimum of 8-10
    A lot depends on individual 'pressing' conditions - on temperature, pressing force, etc. In my case exactly 4 minutes
    give the best result.
    vodiczka wrote:
    This means that you admit that it is not about the differences between CD and vinyl but about how the sound engineer uses them.
    I wrote nothing of the sort. I'm sorry that you didn't understand (?) my post.
    vodiczka wrote:
    It's still more than 30 dB of vinyl, at times 35 dB.
    Yes, but the issue here is not the dynamics of a correctly recorded album but the flattening by the compressor during recording (CD) or playback (RADIO). This artificial procedure gives the first impression (false) of the high volume of the recording and its "dynamics" (inverted commas intended). It is one thing to have a noise interval and another to have the interval from the quietest part of a recording to the loudest. And besides, where did you get vinyl dynamics of 30dB from? Telephones (the kind with a dial and earpiece on a wire) had more.... ;)
    Yes - there's no denying that with every playback the disc loses quality - especially in the high frequency range. This is a fact known since the dawn of time. But a lot also depends on the pressure of the needle on the disc, the guidance of the cartridge and the shape of the needle itself. Here, too, there is not some fixed value that the record loses some quality value after each playback. It is one thing to use 20 G pressure with a sapphire needle (with a few tens of hours of work at best...) and another to use a dynamic cartridge with a diamond needle and HASZIMOTO cut (I think this is how the name is spelled in Polish) with a pressure of 1.2 G. A lot also depends on the way the needle tracks the record. It is true that the "S" arm is more "friendly" to discs to a certain extent, but the best parameters are still given by the linear tracking of the cartridge - that is, the same as when writing the "mother" matrix.
    AS anyway, I don't understand the trend to litter topics with side threads, not directly related to the content of the topic. Is this some kind of competition? Who's going to write more posts not related to the primary thread, or who's going to force how many "straightening" posts through their posts???? And who revels in this? The old users? Shame.
✨ The discussion centers on a microproject involving a simple stereo bar-LED driving indicator using a specific set of LEDs (five green, three yellow, two red) sourced from AliExpress. The design is based on the LM391x series integrated circuits, particularly the LM3914 and LM3915, known for their multifunctional LED bar/dot display capabilities. The LM391x ICs allow for adjustable brightness, scalable LED points (e.g., chaining for 20-point indicators), and linear or logarithmic response characteristics. The main advantages highlighted include simplicity and ease of implementation compared to discrete op-amp comparator circuits, though current consumption increases with more LEDs lit simultaneously.
The project includes PCB design considerations, with debate over single-sided versus double-sided boards, emphasizing the practicality and accessibility of single-sided PCBs for hobbyists despite the complexity of routing. The discussion also touches on the importance of verifying component authenticity when purchasing from AliExpress, as counterfeit or defective parts (e.g., LM3886, LM338) can be common.
Additional technical points include the use of quasi-ideal rectifiers in the input stage, the challenge of peak hold functionality (not inherently supported by LM391x), and the possibility of microcontroller-based implementations for simpler or more feature-rich solutions. The conversation briefly diverges into audio quality debates comparing vinyl and CD formats, highlighting dynamic range, sound characteristics, and recording techniques, but this is ancillary to the main electronics topic.
Overall, the project is a practical example of adapting a classic LED bar indicator IC to a custom LED configuration, with emphasis on learning through PCB design and component selection, while acknowledging the limitations and trade-offs of the LM391x approach.
