Homeassistant MQTT Not Reconnecting and HTTP Server Unresponsive Issues
keCho6oo 900 3
  • Need broker logs and error details
    #1 21568404
    keCho6oo
    Cannot Switch over Homeassistant. Only after switching once on webinterface. I guess the mqtt doesn't reconnect.
    Also sometimes the http server isn't responding directly. Is something blocking it?
    Does it have to do with the power save mode?
    AI: Can you share more details about your Home Assistant setup (version, installation method, and what hardware it's running on)?
    Newest Homeassistant, openbeken firmware.
    AI: Which MQTT broker are you using, and do you see any error messages or logs related to MQTT or the HTTP server when the issue happens?
    Mosquitto
  • #2 21569149
    Rate: 12896
    Can you provide more information, which platform, etc? BL602?
  • #3 21578442
    keCho6oo
    Sorry, this happens on these ANTELA plugs. WiFi Module: Model: CB2S (BK7231N)
  • #4 21580202
    Rate: 12896
    Does it happen if MQTT is not configured? Is the free memory in the Web App log going down?
    I saw similar issue once - do flash backup and try our web app tool to reset rf partition.
