eWeLink BL602 with OpenBeken - Send S1/S2 status to Home Assistant via MQTT
flakerazor 1404 1
Treść została przetłumaczona german » english Zobacz oryginalną wersję tematu
  • #1 21602531
    flakerazor
    I have flashed a Smart Wi-Fi Switch eWeLink with BL602 chip with OpenBeken.
    Firmware: 1.18.133
    Homeassistant via MQTT is paired.
    I would like to have the s1/s2 connection sent to me via MQTT.
    Only the relay circuit is sent to me via MQTT.
    Thanks in advance
  • #2 21602951
    Rate: 12914
    What is the configuration of your device?
    While there are two relays and two switches (S1 and S2), if you assign the ToggleChannelOnToggle role to S1 and S2 and the Relay role to the relays, and assign them two channels (the first pair channel 1, the second pair channel 2), the switches should switch the relays correctly, and any change should be reported to Home Assistant.
