High Bandwidth Peak Current Measurement Circuits: High Side vs Transimpedance Amp
24 13
  • #1 21621239
    Cody Miller
  • #2 21621240
    Joe Wolin
  • #3 21621241
    Cody Miller
  • #4 21621242
    Bob Casiano
  • #5 21621243
    Olin Lathrop
  • #6 21621244
    Cody Miller
  • #7 21621245
    Olin Lathrop
  • #8 21621246
    DAVID CUTHBERT
  • #9 21621247
    Cody Miller
  • #10 21621248
    DAVID CUTHBERT
  • #11 21621249
    Bruce Carter
  • #12 21621250
    DAVID CUTHBERT
  • #13 21621251
    Syafiq Hashim
  • #14 21621252
    Per Zackrisson
The discussion focuses on high bandwidth peak current measurement circuits, comparing high side current sense circuits and transimpedance amplifiers for measuring IC current with bandwidths of at least 100 MHz, ideally up to 1 GHz, to analyze frequency components causing regulatory failures. Key challenges include achieving low inductance and minimal loading on the IC power pins. A practical approach involves using very low inductance current sensing resistors (e.g., 1 ohm or 0.1 ohm) placed close to the IC power pins, connected via wide low impedance transmission lines to an oscilloscope or spectrum analyzer. High frequency current loops and their minimization through PCB layout and bypass capacitors are critical for accurate measurement. Off-the-shelf current probes like Tektronix CT1, CT2, and CT6 offer various bandwidth and current ranges but may introduce excessive inductance. Difference amplifiers with integrated resistors can provide high bandwidth but are limited by stability and gain constraints. Alternative suggestions include measuring radiated emissions with loop antennas. Overall, low inductance, minimal impedance, and careful PCB design are essential for accurate high frequency current measurement in IC testing.
Summary generated by the language model.
