Request for a reduced OpenBeken Version for a smart light control UI
superdau 615 2
  • Request for a reduced OpenBeken build for light UI
    #1 21625319
    superdau
    Hello to all OpenBeken developers,
    actually I am working on a controller software for all sorts of smart lights. This is NOT an app - it is a UI that is located on the Chip itself. So you just need to flash your (Tuya etc.) Bulbs, Floodlights or LED-Strips with OpenBeken, connect to your Wi-Fi, put the files on LFS - and ... here we go!
    No App, no cloud, no spying out of your behavior!
    Your Data belongs to you - nobody else.
    It actually works great on my LSC Smart Outdoor Flood Lights with the CB2L Beken. But I want to use it for other lamps with a ESP-02S (original or replacement) - and I want to give it to the world to show that there is an alternative for all that spyware.
    The controller will be fully compatible with any sort of Smarthome-System - and it will be fully compatible with old mobile devices. Don't throw away your iPhone 4 or your first Samsung - use it as a smart controller for your lights!
    What I am requesting for is a reduced version of OpenBeken only for all sorts of lights as a basis for my UI. Both could even be combined to one system, so the user does not need to download and install the Controller separately.
    ✅ Control your smart lights with your smartphone/tablet via Wi-Fi
    ✅ No data-sucking app
    ✅ No hungry Cloud
    ✅ One System for all Lamps (if the Chip can be flashed with OpenBeken the UI will work)
    ✅ international, self explaining - UI without textual content
    ✅ Can be used with the oldest mobile devices (sustainability!)
    ✅ Free! No cost, no subscription, no ads.
    🇪🇺 IoT the European way! 🇪🇺
  • Suggesting a custom OpenBeken feature build via pull request
    #2 21625359
    max4elektroda
    Help: 49
    Rate: 189
    While I really like to have a "self contained" firmware with all you need to configure in it, I'm not so sure about the request.
    OpenBeken is free and free to configure, so you can build any combination of features you need for your work.
    And what exactly you need on a reduced version is your knowledge ;-)
    Make a pull request with your requirements and your can test and others will be able to test/support for devices you might not own to achieve the goal of working on all platforms.
  • Translator layer maps UI commands to OpenBeken controls
    #3 21625630
    superdau
    I am actually so busy with the UI (downgrading it to HTML5 is hard) and a couple of other IoT-projects that I just don't have the time to dive into OpenBeken development. What I am looking for is an OpenBeken developer (or a group) to cooperate with.
    I already have a solution running where it is not necessary to adapt the UI to the lamp - I use a communication layer ("Translator") between the UI and OpenBeken. This layer translates the internal UI commands (#rgbwc dimmer) into the diverse OpenBeken/Tasmota commands for the different lamps (#rgb, #rgbw, #rgbwc, #rgb temperature, direct pwm-signal ......). It will only be necessary to adapt the Translator - and even this might be done in a UI on the OpenBeken Interface by the user itself. It's just mapping UI commands and Beken/Tasmota Commands - and the more I think about it: this might be done automatically. As soon as OpenBeken knows how to control the lamp it can adapt the Translator by itself.
