OpenBeken Firmware Compatibility for AliExpress Zigbee vs WiFi Ceiling Light
TheZoker 744 3
  • Need chipset details for OpenBeken compatibility
    #1 21539626
    TheZoker
    Hi there,
    I'm currently searching for a ceiling light, which can work with my home assistant.
    I found these ceiling lights on aliexpress:
    https://www.aliexpress.com/item/1005006861681827.html
    There is a zigbee and a wifi version. The zigbee version should work with my ZHA network.
    But in the future I want to flash the light with the OpenBeken firmware.
    Does someone know, if this light can be flashed? I was not able to find it in the database.
    And if yes, should I rather order the wifi or the zigbee version? Can the zigbee version be flashed with OpenBeken as well?
    Thanks!
    AI: Could you please provide the exact product link or the brand and model of the ceiling light you found on AliExpress?
    Tuya Zigbee TS0505B
    AI: Do you know which chipset or controller is used in the WiFi and Zigbee versions of the light, or is that information listed in the product description?
    No
  • #3 21539744
    TheZoker
    Ah nice, thank you very much!
    Did you buy the WiFi version? Is there any instruction online, how to flash them? Thanks!
  • #4 21539849
    ferbulous
    Help: 8
    Rate: 56
    Yes, you’ll need to serial flash it, the firmware’s patched cloudcutter exploit
