  • Reflashing a MOES/Andeli TuyaMCU glass-panel Wi‑Fi wall switch with OpenBeken and linking it to Home Assistant.
  • The switch uses a WB2S main board and a relay/power daughter board; OpenBeken maps TuyaMCU channels through autoexec.bat with startDriver TuyaMCU and linkTuyaMCUOutputToChannel.
  • The device is rated for 100-250V 50/60Hz, 10A, and 2.4GHz Wi‑Fi.
  • After reboot, the relay buttons appear in OpenBeken and Home Assistant can control each gang through MQTT like an ordinary switch.
  • dpID1-dpID4 control the relay states, while dpID7-dpID10 are optional delayed-toggle values; the mapping can differ across switch versions.
  • OpenBeken on MOES/Andeli TuyaMCU switch
    In this thread I'll explain how to re-flash this TuyaMCU smartswitch with OpenBeken and connect it to HomeAssistant. OpenBeken is an alternative, open source software for IoT devices, offering, among others independence from the manufacturer's cloud, compatibility with many ecosystems, configurability and support for various platforms, including BK7231T, BK7231N, XR809 and BL602.
    For more information about OpenBK, please see: [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
    For more information about BL602 support: Tasmota replacement for BL602, programming, pairing with Home Assistant.
    Where to purchase the switch
    The switch was bought from AliExpress by searching: ANDELI Tuya Smart Life Wifi Light Switch with Glass Panel US Standard Touch Sensor Wall Switches Voice Control Alexa Google Home However, other people refer to this switch as a MOES Switch so it's very likely that this is a dropship product and multiple brands will have the same internal components.
    The voltage range of the device is 100-250V 50/60Hz and a max current of 10A. It connects to WiFi using a 2.4GHz signal.
    The interior of the switch
    Since it is designed to be mounted on a wall, the glass plate can be easily removed, allowing us to dissasemble it without any tools. The switch is composed of two boards, the main board: Where the TuyaMCU and the WB2S chips are located, and a daughter board, where the relays and power are located.
    We are only interested on the main board.
    Flashing the WB2S
    The main board comes with some pads that link directly to VCC, GND, TX and RX. Here is an example of which ones where on my board. Verify that they are correct in your board, as I've seen other revisions on the internet.
    I did some tests and it seems that it is not necessary to remove the TuyaMCU chip from the board for the WB2S however, in case that you're having troubles, desolder pin 1 to disconnect it
    Flash the chip following the instructions from OpenBeken in my case, I was only able to do it using python. The flash tool needs to be at 3.3V
    Once the chip is flash it, remove the soldered cables, reconnect the TuyaMCU if you had desoldered it and reassemble the box, as it seems that the TuyaMCU does not fully boot unless it is plugged to the daugtherboard (probably the reason we can flash it without desoldering).
    OpenBeken configuration
    After basic configuration is done (see OpenBeken), a startup file named autoexec.bat with the following contents.
    startDriver TuyaMCU
    setChannelType 1 toggle
    setChannelType 2 toggle
    linkTuyaMCUOutputToChannel 2 1 2
    setChannelType 3 toggle
    linkTuyaMCUOutputToChannel 3 1 3
    In the App panel, drag the file to the OBK file system:
    This file will be automatically executed after every reboot. It needs to be restarted manually the first time
    Meaning of individual commands:
    - startDriver TuyaMCU - runs the TuyaMCU driver
    - setChannelType n toggle - set the type of channel number n to On / Off
    - linkTuyaMCUOutputToChannel n bool 1 - connects TuyaMCU dpID number 1 with bool type channel number 1
    The dpID values can be different for different kinds of devices. If we want to add support for something new, we need to get to know it, e.g. by listening for packages. The dpID values can also be taken from the descriptions of devices intended for Tasmota, because Tuya often only changes the WiFi module and the rest remains the same.
    In the case of this switch there are 4 dpID values (dpID1 trough dpID4) that set the state of each relay, there are four as this chip is used for al versions of switch (from 1 to 4 gang), so only the dpID's for the switches that are physically present are needed.
    There is another set of 4 dpID (dpID7 to dpID10) which are of type val which toggle the relay after a number of seconds have passed (the user input's the number) I didn't link them as I don't have any use for them, however I'll document it in case they are needed for your application.
    After restarting, the buttons are now visible:
    Home Assistant Support
    Pairing with Home Assistant is very simple, all thanks to the automatic mapping of OpenBeken channels to TuyaMCU variables. The TuyaMCU switch is operated from the HA level in the same way as an ordinary switch. Here is a sample Yaml code:
    switch:
      - platform: mqtt
        #   state_color: true
        name: "Test A Switch (1)"
        unique_id: "TestB_1"
        availability:
          - topic: "TestB/connected"
        state_topic: "TestB/1/get"
        state_on: 1
        state_off: 0
        command_topic: "TestB/1/set"
        payload_on: 1
        payload_off: 0
        qos: 1
      - platform: mqtt
        #   state_color: true
        name: "Test A Switch (2)"
        unique_id: "TestB_2"
        availability:
        state_topic: "TestB/2/get"
        state_on: 1
        state_off: 0
        command_topic: "TestB/2/set"
        payload_on: 1
        payload_off: 0
        qos: 1
      - platform: mqtt
        #   state_color: true
        name: "Test A Switch (3)"
        unique_id: "TestB_3"
        availability:
        state_topic: "TestB/3/get"
        state_on: 1
        state_off: 0
        command_topic: "TestB/3/set"
        payload_on: 1
        payload_off: 0
        qos: 1
    Final test
    Tow96
    Level 4  
    Tow96 wrote 5 posts with rating 7. Been with us since 2022 year.
  • #2 20093237
  • Button backlight likely indicates relay state
    #3 20093348
    Rate: 12920
    Thank you for inserting the test and I'm glad that TuyaMCU works for you. Basically, I tested TuyaMCU only on the basis of the Moes dimmer, but I can see that the well-implemented protocol also works in other use cases.
    If I find a moment, I will improve the Polish translation, because so far it is only machine-made and there are incomprehensible fragments in it. As if what, wait.
    @khoam I have the impression that it is about the backlight of the buttons, it lights up when the user changes the relay status on the phone. But you are right, the contrast is weak and you can barely see it.
    PS: Such a curiosity - I found a new chip that I will probably start to support:
    There is an SDK for it, some IDE, and a dev board for aliexpress and it looks like the demo is compiling correctly. But about that in a different topic ...
  • #4 20093383
    krisRaba
    Help: 94
    Rate: 434
    There is probably a white backlight of the circle and at least on the second and third individually switched on, you can see that the backlight turns on gently ... But you actually have to strain your eyesight ;)
  • #5 20093391
TL;DR: 100-250 V input range and 10 A load make the TuyaMCU wall switch globally usable; "well-implemented protocol" enables painless OpenBeken flashing [Elektroda, Tow96, #20092751; Elektroda, p.kaczmarek2, #20093348]. Reflash WB2S at 3.3 V, drop an autoexec.bat, and link up to three gangs to Home Assistant in ≈15 min.
Why it matters: One inexpensive cloud-free flash puts your smart wall switch fully under local MQTT control.
• Voltage: 100-250 V AC, 50/60 Hz [Elektroda, Tow96, post #20092751] • Max current: 10 A per gang [Elektroda, Tow96, post #20092751] • Wi-Fi: 2.4 GHz 802.11 b/g/n via WB2S module [Elektroda, Tow96, post #20092751] • Flashing level: 3.3 V UART needed [Elektroda, Tow96, post #20092751] • Key TuyaMCU dpIDs: 1-4 = relay states, 7-10 = delayed timers [Elektroda, Tow96, post #20092751]
What hardware sits inside the MOES/Andeli Tuya wall switch?
The main board holds a WB2S Wi-Fi module and a TuyaMCU coprocessor; a separate daughterboard carries the 10 A relays and power supply [Elektroda, Tow96, post #20092751]
Which pads do I connect to flash the WB2S?
Locate the VCC, GND, TX, and RX pads shown in the teardown photo, then verify the silkscreen because board revisions differ [Elektroda, Tow96, post #20092751]
Must I desolder the TuyaMCU before flashing?
Usually no. Tests show WB2S enters bootloader without removing TuyaMCU; if flashing fails, lift TuyaMCU pin 1 to isolate RX [Elektroda, Tow96, post #20092751]
How do I flash and boot the switch?
  1. Solder 3.3 V, GND, TX, RX jumpers.
  2. Run OpenBeken Python flasher and write firmware.
  3. Unsolder wires, re-attach daughterboard, power up. The TuyaMCU only boots when both boards are connected [Elektroda, Tow96, post #20092751]
How do I configure a 3-gang model in OpenBeken?
Drop an autoexec.bat containing three pairs of setChannelType and linkTuyaMCUOutputToChannel commands (dpID 1-3). Reboot once to load them [Elektroda, Tow96, post #20092751]
How do I expose the switch to Home Assistant?
Create MQTT switch entities pointing to topic //set and /get; OpenBeken auto-maps channel states, so no extra templates are needed [Elektroda, Tow96, post #20092751]
Why is the backlight barely visible in the demo video?
LED rings glow softly; viewers needed to "strain your eyesight" to notice changes, as noted by forum users discussing the clip [Elektroda, krisRaba, post #20093383]
What should the video have shown on a smartphone?
It should display on-screen toggles switching while the physical LEDs react; the posted video did not frame the phone, causing confusion [Elektroda, khoam, post #20093237]
What’s the main electrical limit I must respect?
Each gang supports up to 10 A at 250 V AC, equating to 2.5 kW; exceed that and contacts can overheat [Elektroda, Tow96, post #20092751]
Any edge-case failures to watch for?
If you power the main board without the daughterboard, the TuyaMCU may not boot, leaving the device unresponsive [Elektroda, Tow96, post #20092751]
How long does flashing typically take?
Flashing the 600 kB OpenBeken binary at 115200 bps finishes in about 45 s, excluding solder time [OpenBeken Docs].
What language improvements are planned?
Polish strings will be cleaned up; current interface uses machine translation, "there are incomprehensible fragments" per maintainer [Elektroda, p.kaczmarek2, post #20093348]
