How to Build a Soft Start RC Ramp Circuit for 12V 1.2A DC Motor to Prevent Wheel Slip
660 7
  • RC ramp idea needs a motor driver, not just resistor-capacitor
    #1 21660416
    Brian Buick
  • #2 21660417
    Steve Lawson
  • #3 21660418
    Cody Miller
  • RC gate drive soft-start for low-side FET
    #4 21660419
    David Deleonardo
  • FET dissipation during motor startup ramp
    #5 21660420
    Steve Lawson
  • LTspice soft-start simulation with Miller capacitance
    #6 21660421
    David Deleonardo
  • FET soft-start for relay-driven 12 V motor
    #7 21660422
    Brian Buick
  • #8 21660423
    Steve Lawson
A 12V, 1.2A geared DC motor with a small 3-inch wheel experiences wheel slip due to rapid startup when powered directly at 12V. The goal is to implement a soft start ramp circuit that gradually increases voltage over 100-200ms to prevent slipping. A simple RC (resistor-capacitor) approach in series with the motor is ineffective due to voltage drop and power dissipation in the resistor. Instead, a PWM (Pulse Width Modulation) control or a MOSFET-based soft start circuit is recommended. The MOSFET method involves placing a FET between the motor's negative terminal and ground, controlling the gate voltage with an RC network to ramp the gate voltage slowly, thus controlling motor startup current. This approach requires careful selection of the FET and heat dissipation measures, as the FET will dissipate significant power during ramp-up. LTspice simulations demonstrate the feasibility of this method, showing current ramp times and power dissipation in the FET. The motor is used in a custom R2D2 robot head, driven by an Arduino-controlled relay, where short bursts of motor activation rotate the dome on a Rockler bearing. The soft start circuit aims to reduce motor slip and noise during these movements.
