Powering Two TDA7294 Amplifiers With 95-0-95V Transformer for Stereo Audio Build
1080 8
  • Need a supply design for dual TDA7294 amps
    #1 21679022
    Rick Merino
  • Toroidal transformer surge and ±40V limit for TDA7294
    #2 21679023
    PeterTraneus Anderson
  • Recommend using a lower-voltage transformer instead
    #3 21679024
    David Ashton
  • #4 21679025
  • Parallel wiring of both ICs from one transformer discussed
    #5 21679026
    Rick Merino
  • Question about parallel or series wiring for two TDA7294s
    #6 21679027
    Rick Merino
  • Shared rails are fine with added reservoir capacitance
    #7 21679028
    David Ashton
  • #8 21679029
  • Center-tapped transformer needed for dual supply wiring
    #9 21679030
    Rick Merino
The discussion centers on powering two TDA7294 audio amplifier ICs for a stereo build using a 95-0-95V transformer with a 120V primary. The TDA7294 ICs have a maximum input voltage rating of ±40V DC, making the existing transformer output too high for direct use. It is advised to use a transformer with a secondary voltage closer to ±40V to avoid damaging the ICs. Power supply design considerations include managing turn-on surges typical of toroidal transformers and ensuring sufficient capacitance on the power rails to handle peak current demands without excessive voltage drop. Wiring both amplifiers in parallel from a suitable dual ±40V supply is feasible and commonly practiced, as the TDA7294 has good power supply rejection and minimal interaction between parallel loads. Wiring the amplifiers in series from a higher voltage supply is not recommended due to differing current draws causing uneven voltage distribution. Suggestions include purchasing an appropriate transformer with a center-tapped secondary for dual polarity supply or using voltage regulation or DC-DC converters, though the latter may be costly. A specific Hammond Manufacturing transformer (model 185G36) was proposed as a suitable replacement, with clarification sought on center tap presence and dual voltage supply capability.
