Earth Well Resistance Calculation Formula for Copper Plate, Depth, Soil Resistivity
414 9
How do I calculate the resistance of a copper-plate earth well from its depth, plate size, and soil or conductive-concrete resistivity?
There is no single hard standard formula for an earth well’s resistance, because the result depends on soil type, moisture content, conductor surface area, and the geometry of the grounding electrode [#21663756] The thread suggests that acceptable grounding is usually defined by local building codes, and that those codes may specify minimum conductor size such as #6 AWG bare solid copper rather than a universal resistance value [#21663756] The quantity of power to be dissipated also affects how large the earth ground must be [#21663757] If you need practical guidance, the replies point to soil-resistivity references and grounding construction/testing material rather than a single closed-form equation [#21663757] [#21663760] [#21663762]
  • Request for earth well resistance formula
    #1 21663755
    rohollah Baziar
  • Ground resistance depends on soil and conductor area
    #2 21663756
    Chuck Sydlo
  • #3 21663757
    Chuck Sydlo
  • #4 21663758
    Frank Bushnell
  • #5 21663759
    Chuck Sydlo
  • #6 21663760
    Chuck Sydlo
  • #7 21663761
    rohollah Baziar
  • Suggesting conductive powder and SWER references
    #8 21663762
    Chuck Sydlo
  • #9 21663763
    khoa nguyen
  • #10 21663764
    Luann Schueler
The discussion centers on calculating the earth well resistance for a grounding system involving a copper plate placed in a 4 to 6 meter deep well filled with conductive concrete and soil. Key factors influencing resistance include soil resistivity, depth of the well, surface area of the copper plate, and the resistivity of the conductive concrete. There is no widely recognized standard formula explicitly for "earth wells," but grounding resistance depends on soil type, moisture content, and conductor surface area. References to building codes such as NEC 2011 specify minimum conductor sizes (e.g., #6 AWG bare solid copper) but do not provide direct formulas for earth well resistance. The concept of earth wells is related to grounding grids and Single Wire Earth Return (SWER) systems, which rely on earth conductivity and have specific grounding requirements. External resources include soil resistivity data and grounding system design guides, such as the Weschler technical reference on grounding methods. The discussion also clarifies misconceptions about large-scale grounding conductors, noting that large earth conductors may be arranged in circular paths rather than solid plates of extreme size.
