CT Quadriplegic needs help with modified van electronic issues
315 6
  • Starter stuck engaged after ignition off
    #1 21677611
    Wayne Macauley
  • Suggesting a battery-current leak and overamp issue
    #2 21677612
    Michael Gourgy
  • Parallel batteries do not increase device current draw
    #3 21677613
    richard gabric
  • Deep cycle battery may not suit starter load
    #4 21677614
    richard gabric
  • #5 21677615
    Wayne Macauley
  • Isolated auxiliary batteries and momentary start relay suspected
    #6 21677616
    Wayne Macauley
  • Suggesting college students diagnose the van fault
    #7 21677617
    Chip Fryer
A quadriplegic owner of a heavily modified 1991 Ford E150 van equipped with Electronic Mobility Corporation modifications is experiencing persistent electrical issues, including repeated starter and solenoid failures over six months. The van uses multiple Optima Yellow Top dual-purpose batteries wired in parallel and series configurations to power both starting and auxiliary systems, including a CB radio and 12V devices. The main concerns include potential electrical leaks, relay or tactile switch failures in the start push-button system, and possible overcurrent conditions damaging OEM-rated components. Discussion highlights the importance of proper diagnosis by a skilled auto electrician rather than part replacement, the impact of battery wiring on amperage and voltage, and the suitability of battery types for starting loads. Suggestions include isolating auxiliary batteries, verifying relay contacts, and seeking assistance from technical colleges or electronics clubs for thorough troubleshooting and repair.
