AMS1117 Breadboard Power Supply Units: Reliability, Heat Issues, and Regulation Quality
621 11
Can cheap breadboard power supply modules with an AMS1117 regulator reliably provide regulated 3.3 V or 5 V for breadboard prototypes?
Yes, they usually regulate well enough for breadboard prototypes as long as you keep the load modest and stay within the regulator’s thermal limits [#21682999][#21683008] The AMS1117 is a linear regulator, so it wastes the voltage drop as heat; for example, with 9 V in, 5 V out, and 100 mA load it dissipates about 400 mW and rises about 22°C at 55°C/W, but at 1 A it would try to rise about 220°C and fail [#21682999] Cheap boards may have poor thermal layout, so the advertised 1 A rating is likely optimistic; in practice one user notes they have worked up to about 600 mA without failure [#21682999][#21683002] If you need to improve reliability, add a small heatsink to the regulator or use a switching regulator instead [#21683001][#21683003] Their output should be stable enough for chips if the input DC is adequately smoothed and not excessively noisy [#21683008]
  • AMS1117 breadboard regulators can overheat and fail
    #1 21682998
    Michelle OBrien
  • AMS1117 thermal limits make 1A ratings misleading
    #2 21682999
    Elizabeth Simon
  • Breadboard regulator modules work if lightly loaded
    #3 21683000
    Conrad Mannering
  • Small heatsink and thermal adhesive for AMS1117 regulators
    #4 21683001
    Rick Curl
  • Adafruit AMS1117 modules reliable up to 600 mA
    #5 21683002
    Duane Benson
  • #6 21683003
    David Ashton
  • TO-220 switching and boost regulator replacements
    #7 21683004
    Joe Farr
  • #8 21683005
    Michelle OBrien
  • #9 21683006
    Conrad Mannering
  • Shunt cheap breadboard regulators for reliability
    #10 21683007
    Justin Spencer Mamaradlo
  • Reliability depends on genuine parts and good input smoothing
    #11 21683008
    Joe Farr
  • Two units failed with shorted regulators
    #12 21683009
    AlanE
AMS1117-based breadboard power supply units provide regulated 3.3V or 5V outputs from 6-12V DC inputs and are popular for prototyping due to their compact form factor and low cost. These units use linear voltage regulators (AMS1117), which inherently dissipate heat proportional to the voltage drop and current load, often causing the regulator to become hot or fail if operated near their 1A maximum rating without adequate heat sinking. The AMS1117 regulator offers thermal and short-circuit protection but has a thermal resistance around 55°C/W, limiting safe power dissipation. Users report stable voltage regulation suitable for powering microcontrollers and sensors when operated within thermal limits and current ratings (typically below 700mA to 1A). Adding small aluminum heatsinks with thermally conductive adhesive can significantly reduce regulator temperature and improve reliability. Some users have experienced regulator failures due to poor quality control, including short circuits between input and output rails, which can damage connected devices. Alternatives suggested include using switching regulators (e.g., based on the 34063 IC) or replacing linear regulators with switching modules to improve efficiency and reduce heat. Bench power supplies or modified ATX power supplies are recommended for higher current or more reliable operation. Capacitor quality and proper input smoothing also affect output stability. Overall, AMS1117 breadboard power supplies are adequate for low to moderate current prototyping but require careful thermal management and quality consideration.
TL;DR: AMS1117 boards run hot: best-case 55°C/W; at 9V→5V and 100 mA they dump 0.4 W. “Advertising these things as 1A regulators is misleading.” [Elektroda, Anonymous, post #21682999]
Why it matters: If you prototype MCUs or sensors, heat limits current and reliability, so you must size input voltage, cooling, and load correctly.
Are AMS1117 breadboard power supplies good enough for chips?
Yes, when kept within thermal limits. The linear regulator holds output stable if you avoid overheating. Use proper input voltage and do not chase the headline “1A.” This keeps microcontrollers and logic ICs within safe margins during prototyping. [Elektroda, Anonymous, post #21682999]
Why do these boards get so hot?
They are linear. Heat equals (Vin − Vout) × I. At 9 V in, 5 V out, and 100 mA, the regulator burns 0.4 W. With ~55°C/W thermal resistance, that is ~22°C rise, and much higher at larger currents. Push 1 A and the device overheats or fails. [Elektroda, Anonymous, post #21682999]
How much current can I realistically draw?
Keep well below the advertised 1 A unless input–output voltage is tiny and cooling is excellent. At 9 V→5 V, 1 A implies a 4 W drop, which exceeds safe dissipation on these small boards. Users commonly stay ≤600 mA to avoid trips and failures. [Elektroda, Anonymous, post #21683002]
What input voltage should I choose for 5 V or 3.3 V output?
Use the lowest input that still meets dropout margin to cut heat. Many users feed only what is needed for the selected output, rather than a full 12 V. That simple choice improves reliability and keeps fingertips safe. [Elektroda, Anonymous, post #21683000]
Do tiny heatsinks actually help on AMS1117 boards?
Yes. A small 8×8 mm or 10×10 mm aluminum heatsink attached with thermal adhesive reduces junction temperature and can prevent shutdown. “Heatsink plaster” silicone adhesive works and is easy to apply. It is a cheap, quick win. [Elektroda, Anonymous, post #21683001]
Are there proven success stories with these modules?
Yes. Several builders powered microcontrollers, sensors, and dev boards at 3.3 V and 5 V, often from a 9 V source, sometimes with a small heatsink. Reported current was about 600 mA or less without failures. [Elektroda, Anonymous, post #21683002]
What failure modes should I watch for?
Quality control varies. Some units failed with the 5 V or 3.3 V regulator shorted, backfeeding full input (e.g., 12 V) into the rails and even the USB port. Treat unknown units cautiously and test before powering valuables. [Elektroda, Anonymous, post #21683009]
How clean is the output voltage for digital logic?
Regulation is fine if you stay within thermal limits and use a smooth DC input. When powering from a switching adapter, ensure adequate filtering to keep switching noise off the rails. Good capacitors matter here. [Elektroda, Anonymous, post #21683008]
Is a bench power supply a better investment?
For flexibility and reliability, yes. A bench PSU serves many projects, supports current limiting, and avoids breadboard thermal constraints. Some users buy new or second‑hand units and route the rails from the bench supply. [Elektroda, Anonymous, post #21683000]
What are switching-regulator alternatives to AMS1117?
A switching design, such as one built around the MC34063, improves efficiency and current headroom. It reduces heat at the same load because it does not burn off voltage as heat. This suits higher-current breadboard work. [Elektroda, Anonymous, post #21683003]
Is there a drop‑in replacement for the linear regulator?
Yes. TO‑220‑pinout switching‑regulator modules exist in fixed 3.3 V and 5 V options. They can replace a 7805‑style LDO footprint and deliver more current with less heat, useful for retrofits and compact builds. [Elektroda, Anonymous, post #21683004]
How do I keep my board from overheating? (3 steps)
  1. Use the lowest input voltage that meets dropout for your chosen output.
  2. Add a small 8–10 mm heatsink with thermal adhesive.
  3. Keep current modest; avoid long runs near the claimed maximum. [Elektroda, Anonymous, post #21683001]
Can I parallel two boards to share the load?
For non‑critical builds, some users shunt regulators or parallel two cheap boards to spread current. This is a workaround when ratings seem optimistic, but monitor heat and matching carefully to avoid imbalance. [Elektroda, Anonymous, post #21683007]
What is the AMS1117?
AMS1117 is a low‑dropout linear voltage regulator commonly used on these breadboard power modules to provide 3.3 V or 5 V from a higher DC input. It is simple but dissipates heat proportional to voltage drop and load current. [Elektroda, Anonymous, post #21682998]
What is the MC34063?
MC34063 is a classic switching regulator IC for buck, boost, or inverting converters. Using it in a breadboard PSU provides higher efficiency than an AMS1117, enabling more current with less heat in compact projects. [Elektroda, Anonymous, post #21683003]
