[Solved] Sonoff SNZB-04 - which application to configure the door opening sensor?
JORGEN1970 744 11
How do I set up and use a Sonoff SNZB-04 door opening sensor in eWeLink?
You need the eWeLink app plus a ZigBee gateway/bridge; the SNZB-04 cannot be paired directly to eWeLink like a Wi‑Fi device. The sensor uses ZigBee, so you first connect a ZigBee gateway such as the Sonoff Bridge Pro or another ZigBee 3.0 gateway, and then add the sensor to that gateway in eWeLink [#21689527] [#21689655] ZigBee devices need this bridge to connect to the internet and the app [#21689527] The gateway also lets ZigBee devices form their own low-power network and operate without Wi‑Fi cluttering the router [#21689941] After buying the gateway, the user reported that everything worked [#21692101]
  • #1 21689331
    JORGEN1970
    Rate: 18
    Sonoff SNZB-04 door opening sensor what application to use to start.
    Added after 1 [minute]:
    Hello, I have purchased a Sonoff SNZB-04 door opening sensor, I do not really know what application I can use to run it, please help.
  • #3 21689490
    JORGEN1970
    Rate: 18
    Thank you very much. I had not read it because it was not available in Polish.
    Added after 6 [minutes]:
    Well what does it mean : choose a bridge? I don't quite understand what bridge means help.
  • #4 21689527
    bubu1769
    Help: 1177
    Rate: 2375
    The Sonoff SNZB-04 uses ZigBee communication.
    To use it, it is necessary to have a special device, a gateway, which enables ZigBee devices to connect to the internet and thus to the operating application.
  • #5 21689536
    JORGEN1970
    Rate: 18
    Okay, but this communicator ? device or is this ZigBee application? Please tell me because I don't understand. I have the Ewelink application.
    Do I need to buy anything else to be able to use it with the Ewelink?
    bubu1769
    Help: 1177
    Rate: 2375
    You must have something like this
    https://allegro.pl/oferta/centrala-sterujaca-sonoff-bridge-pro-17687951124
    Or another manufacturer
    https://allegro.pl/oferta/mini-bramka-central...elink-inteligentny-dom-zigbee-3-0-17679983249
    In the eWeLink app you connect to the gateway/bridge and only then can you connect to devices over ZigBee.
  • #7 21689673
    JORGEN1970
    Rate: 18
    thank you very much, bubuś, i am already buying this gate. Explain to me what is the technical purpose of using such a gateway? Can't they be paired straight away like the others that you can see right away in EWELINK? What are these gates for?
  • #9 21689908
    JORGEN1970
    Rate: 18
    This I think I am beginning to understand in such a configuration the devices can consume very little energy.
  • Advantages of ZigBee over Wi-Fi for smart home devices
    #10 21689941
    bubu1769
    Help: 1177
    Rate: 2375
    This is one of the advantages of ZigBee.
    By creating their own network they don't clutter the Wi-Fi signal and don't clog up the router, at my place I had to make a separate Wi-Fi router just for the Smart Home devices because the wireless internet at home was pulling a maximum of 30 Mbps.
    Also, having already set up the whole ZigBee system with the gateway, they work together even when there is no Wi-Fi at all.
    This is why I am slowly moving to this type of communication.
  • #11 21689952
    JORGEN1970
    Rate: 18
    And very well .
  • #12 21692101
    JORGEN1970
    Rate: 18
    Thanks to the help of @bubu1769, I bought a gateway and everything is working.
The Sonoff SNZB-04 door opening sensor operates using ZigBee communication protocol, requiring a ZigBee gateway (bridge) to connect the sensor to the internet and the eWeLink application. The gateway acts as a central hub that enables ZigBee devices to network and communicate with the app, as ZigBee devices cannot connect directly without it. Examples of compatible gateways include the Sonoff Bridge Pro and other ZigBee 3.0 mini gateways supported by eWeLink. Using ZigBee reduces Wi-Fi congestion and allows devices to operate with low power consumption, maintaining functionality even without Wi-Fi. The gateway is essential for integrating the SNZB-04 sensor into a smart home system via the eWeLink app.
TL;DR: The Sonoff SNZB‑04 is a Zigbee sensor that requires a Zigbee gateway/bridge for the eWeLink app; one user noted a 30 Mbps Wi‑Fi bottleneck and said, “devices network themselves but need a gateway.” [Elektroda, bubu1769, post #21689941]
Why it matters: This FAQ shows how to get your SNZB‑04 working fast, explains the "bridge" requirement, and helps you choose the right setup if you’re asking “which app do I use?” and “do I need extra hardware?”
Which app should I use to set up the Sonoff SNZB‑04 door sensor?
Use the eWeLink app, but only after adding a compatible Zigbee gateway/bridge to your eWeLink account. Then pair the SNZB‑04 through that bridge. [Elektroda, bubu1769, post #21689655]
Do I need to buy extra hardware, or can I pair the SNZB‑04 directly to my phone or Wi‑Fi?
You need a Zigbee gateway/bridge. The SNZB‑04 speaks Zigbee, not Wi‑Fi, so it cannot connect directly to your router or phone. [Elektroda, bubu1769, post #21689527]
What does “bridge” or “gateway” mean for Zigbee?
A Zigbee bridge is a hub that joins your Zigbee devices into a local mesh and provides the internet link for the eWeLink app. It is required for control and automation. [Elektroda, bubu1769, post #21689527]
How do I pair the SNZB‑04 in eWeLink?
  1. Add and connect a compatible Zigbee bridge inside eWeLink.
  2. Put the SNZB‑04 in pairing mode near the bridge.
  3. In eWeLink, choose Add Device via the bridge and complete pairing. “Connect to the gateway first, then add Zigbee devices.” [Elektroda, bubu1769, post #21689655]
Will the sensor keep working if my home Wi‑Fi goes down?
Yes. After setup, Zigbee devices continue to interact locally through the bridge, even without Wi‑Fi. Cloud features pause, but automations can still run. [Elektroda, bubu1769, post #21689681]
Why pick Zigbee over pure Wi‑Fi sensors?
Zigbee forms its own mesh, reduces Wi‑Fi congestion, and suits battery devices. One user reported only 30 Mbps when Wi‑Fi smart gear crowded the network, prompting a shift to Zigbee. [Elektroda, bubu1769, post #21689941]
Does the SNZB‑04 work with eWeLink out of the box?
Yes, with a compatible Zigbee bridge. In eWeLink, add the bridge first; only then will the app discover the SNZB‑04 as a new device. [Elektroda, bubu1769, post #21689655]
I added the sensor in eWeLink but it doesn’t appear. What’s wrong?
You likely tried to add it without a Zigbee bridge. Add a supported bridge to eWeLink, then re‑pair the SNZB‑04 through the bridge. [Elektroda, bubu1769, post #21689655]
Is Zigbee really lower power for door sensors?
Yes. Users cite low energy use as a key benefit for contact sensors, which helps extend battery life. “This configuration can consume very little energy.” [Elektroda, JORGEN1970, post #21689908]
What exactly is Zigbee?
Zigbee is a wireless protocol for smart‑home devices that creates a self‑healing mesh. Devices talk locally, while a gateway links them to your app. [Elektroda, bubu1769, post #21689681]
Can I mix brands for the Zigbee bridge and sensor?
Yes, you can use other manufacturers’ Zigbee 3.0 bridges that work with eWeLink. Add the bridge in eWeLink, then pair the SNZB‑04. [Elektroda, bubu1769, post #21689655]
What’s the real benefit of the bridge beyond internet access?
The bridge keeps the Zigbee mesh running locally. Devices can still interact and trigger automations during internet outages or router issues. [Elektroda, bubu1769, post #21689681]
Any setup tips to avoid Wi‑Fi slowdowns with smart devices?
Move battery sensors and simple triggers to Zigbee. This offloads traffic from your main Wi‑Fi. A user saw a 30 Mbps cap before segmenting networks. [Elektroda, bubu1769, post #21689941]
I followed this guidance—did anyone confirm success?
Yes. The original poster returned to confirm that after buying a gateway, everything worked with the SNZB‑04. [Elektroda, JORGEN1970, post #21692101]
