[Solved] ESP32 WROOM: error Wrong boot mode detected (0x17) - how to set the download mode?
PRL 3396 9
How can I fix an ESP32 WROOM that shows “Wrong boot mode detected (0x17)” and needs download mode?
Try setting the bootloader mode in the Arduino IDE to the old one; that was suggested as the main fix for this error [#21714757] Also make sure the board is detected as a COM port in Device Manager and that the correct driver is installed, because without a driver you will not get anywhere [#21715355] Check that you selected the correct ESP32 board model in Arduino IDE, since there are many variants and the model is often marked on the board itself [#21715861]
  • #1 21714609
    PRL
    Help: 953
    Rate: 910
    Welcome.
    My EPS32 WROOM has broken down.
    I have this error:
    A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0x17)! The chip needs to be in download mode.
    Is it possible to fix it somehow?
  • #2 21714757
    konradkarnisz
    Rate: 8
    Try setting the bootloader mode in the Arduino IDE to the old one. It usually solves the problem.
  • #4 21715355
    konradkarnisz
    Rate: 8
    First of all, I would check that the board is detected as a com port in the device manager and the description should be there. Without a driver, you won't get anywhere.
  • #5 21715861
    konradkarnisz
    Rate: 8
    Have a look at your board there should be such a chip in soic 18 if I am not mistaken. Read the name off it, type it in the search engine with the word driver. In Arduino ide you also have to set the right board model, because there are many of them. It probably says on the back of the board.
  • #6 21719869
    PRL
    Help: 953
    Rate: 910
    The problem is that the system was working. When sending the program via OTA, there was a disconnection and it hasn't worked since. I guess it will just be binned.
  • #7 21720031
    konradkarnisz
    Rate: 8
    I would replace the chip there is probably ch340 but it depends on the version.
  • #8 21720045
    Chris_W
    Help: 386
    Rate: 1051
    PRL wrote:
    The problem was that the circuit was working. When sending the program via OTA, there was a disconnection and it hasn't worked since. I guess it will just be bin.
    One by one, write the story of what is happening.
    The message is during OTA flashing?
    I've had instances of various errors during OTA - it crashes the device programmatically - but through the uart it usually goes and fixes it.
  • #9 21720234
    PRL
    Help: 953
    Rate: 910
    Chris_W wrote:
    In turn, write
    I loaded the program with OTA support.
    I loaded the patches via WiFi several times. One failed and since then there is the above mentioned error.
    After connecting the board the port is detected, but sending the program ends with the mentioned error.
An ESP32 WROOM module encountered a "Wrong boot mode detected (0x17)" error after a failed OTA firmware update via WiFi, causing the device to become unresponsive to programming attempts. The board is still detected as a COM port, but flashing fails with the same error. Suggested troubleshooting steps include verifying the correct COM port and driver installation (e.g., CH340 USB-to-serial chip), ensuring the correct board model is selected in the Arduino IDE, and trying to set the bootloader mode to the older version in the IDE. OTA failures can cause programmatic crashes that may be recoverable via UART flashing. However, due to the low cost of the module, the user opted to discontinue repair efforts.
