Turning Off WBR3 Module WiFi and Bluetooth in Automatic Cat Litter Box
speedtaxi 699 6
  • #1 21753540
    speedtaxi
    Hello, is it possible to turn a WBR3 module off?
    It is installed in an automatic cat toilet. I don't have Wi‑Fi signal so I don't want the module to send Bluetooth and Wi‑Fi signals permanently during the whole day and night while we sleep.
    Thank you.
  • #2 21753587
    Rate: 12914
    Hey, how your WiFi litter box looks like, what is the device exact model, is it battery-powered or mains powered?
    Do you want to modify the device firmware or just turn off the WBR3 (if possible)?
  • TuyaMCU may work with WBR3 disconnected
    #4 21753756
    Rate: 12914
    I don't think there is an easy and non-invasive way to do it, however, if your device is TuyaMCU, there is some chance it can work with WiFi module disconnected. Still, that's a risky mod and it requires some basic skills and knowledge. Are you really willing to try?
    What is the motivation behind the WBR3 removal?
    I don't think that unpaired Tuya device sends any WiFi signal. It could scan BT if in Easy pairing mode, and create AP (WiFi), but only in AP Pairing mode.
  • #5 21753910
    speedtaxi
    Hi, thanks for answering.
    You said that maybe an unpaired module doesn't send any Wi-Fi and any BT signal. If that is so, it is perfect.
    So I would reset the little box.
    But how do I know if there are any signals being sent?
    But if not, I would take the risk to disconnect the module.
    I hope the little box would work with a disconnected module.
    Thank you
  • #6 21753988
    Rate: 12914
    Well, WiFi most likely is not broadcasted, if it is, do you see the SmartLife AP broadcasted? When you use your mobile phone to search for WiFi networks around? I guess it's not broadcasted.
    Then comes the Bluetooth - when you run Tuya App on phone, does it see the device?
    Still, why are you worried about it?
  • #7 21754310
    speedtaxi
    Thank you. I will try to reset the litter box, and I will see if my phone shows any Wi-Fi or Bluetooth signal.
    The litter box is not far from the bedroom, and I try to shut down any device with electromagnetic radiation at night while sleeping.
The discussion addresses the possibility of disabling the WBR3 WiFi and Bluetooth module integrated into a mains-powered automatic cat litter box. The device model is identified via an Amazon listing as the TRIUMPHKEY Self-Cleaning Eliminator Automatic Multi BBCat. It is noted that turning off the WBR3 module is not straightforward and may require invasive modifications or firmware changes. If the device uses a TuyaMCU platform, disconnecting the WiFi module might be feasible but involves risk and technical expertise. Additionally, unpaired Tuya devices typically do not emit continuous WiFi signals; WiFi and Bluetooth transmissions occur mainly during pairing modes such as Easy pairing or AP Pairing mode.
