OpenBK Mini Wall Switch: How to Set Toggle Logic Like Shelly With DigitalIn and Rules?
erdeidominik1999 438 1
  • Need toggle-style switch input logic in OpenBK
    #1 21784765
    erdeidominik1999
    Hello!
    I have a mini wall switch where I want to use the switch input with a switch-type logic. With Shelly when using toggle logic the power-on of the channel always the high of the input channel (the analog switch is always powered on in one direction). How can I set this logic in openbk? Maybe with digitalIn and rules? So I want that if I switch on the relay with the manual switch then switch off over Wi-Fi, after, when I want to switch back on with manual switch I need to click the switch and click back to the power-on position.
  • #2 21785933
    Rate: 12945
    I am not sure if I understand, but maybe, by any chance, you just want to use TglChannelOnToggle pin role?
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/ioRoles.md
    Table row with ToggleChannelOnToggle entry and pin function description
