MOUSE JIGGLER pretending to be a computer mouse
janchar 4074 31
  • A Raspberry Pi Zero (RP2040) Arduino mouse jiggler emulates a USB computer mouse to keep Windows from entering standby during inactivity.
  • It moves the pointer 5 pixels to the right every 1 minute, then moves it back 5 pixels, avoiding the erratic cursor behavior of commercial jigglers.
  • A soldered button between pin 1 and pin 3 toggles activation, while the RGB LED shows operating status.
  • Uploading is done in Windows 10 by holding BOOT, opening the USB folder, and copying RP2040_simulation_motion_mouse.ino.uf2.
  • #31 21806338
    teresakier
    Something feels that if this continues, I could use something like this at work. With the new changes, screens go blank after a few seconds of inactivity ;/
  • #32 21808191
    Jurek_I
    In fact, probably the easiest solution without installing anything is to run e.g. Notepad, and put something heavy enough on the spacebar key to keep it pressed all the time :)
