Minitest: Camecho 10" LCD Monitor 1024x600 VGA HDMI BNC AVI presentation with camera
p.kaczmarek2 1482 4
  • A Camecho 10-inch LCD monitor with 1024x600 resolution is tested as a surveillance display and possible Raspberry Pi screen.
  • The kit includes a remote control, a 12 V 2 A power supply, HDMI/VGA/RCA/BNC cables, USB media playback, and OSD picture and sound settings.
  • The monitor costs PLN100 to PLN200, depending on promotions and seller.
  • Image quality and viewing angle are considered acceptable, and it works with a PAL camera over BNC, but the price feels high and the foot could be heavier.
  • CAMECHO 10-inch LCD monitor box showing the screen image and “DC:9–30V” text
    Here's a short test of a tiny 10-inch surveillance monitor bought from a Chinese mail order site. Here I will measure its power consumption and test its performance with a single PAL camera. How much does it cost to use such a monitor? Will it be suitable for the Raspberry? Let's find out!
    Screenshot of a Podof0 10.1-inch monitor listing with price 185.19 zł and accessory photos
    The device is available for between PLN100 and PLN200, depending on promotions and where you buy.
    Side of a box labeled “Installation Steps” with three drawings showing how to mount a monitor stand Specification table on a 10.1-inch monitor box, listing DC 9–30 V power and HDMI/VGA/BNC inputs Side of a box showing monitor ports diagram: power, VGA, HDMI, AV, R/L audio, USB, and BNC Section of a box with service icons and CAMECHO support email address
    The kit turns out to be quite rich. We even get a remote control. In addition, we have a 12 V 2 A power supply and a full set of cables, including HDMI, VGA, RCA and even BNC.
    Box contents: remote, power adapter, and cables (incl. HDMI, VGA, RCA, BNC) in plastic bags
    Instructions:
    Manual pages for “10.1'' HD LCD Color Monitor” showing product image and AV, VGA, BNC, HDMI inputs Monitor manual page showing functions, inputs, and a labeled remote control diagram
    The monitor looks surprisingly solid, I expected the cheapest plastic.
    Small black LCD monitor on a white surface, with control buttons along the bottom bezel. Rear of a small monitor with speaker grilles and ports: VGA, HDMI, RCA, USB, and BNC
    The device has a bit more functionality than I thought. There's USB support, you can view photos, play music, movies, etc. You can change picture settings, aspect ratio, colour temperature, similarly there are sound settings. There is also a clock available along with on/off and sleep time. The OSD language can also be changed.
    Small black monitor on a desk showing a media menu and the message “No Device”. Small black monitor showing the picture settings menu, with control buttons along the bottom edge 10-inch monitor showing the sound settings menu; a finger presses the “+” button on the bottom panel
    Small black monitor showing “Clock” menu; a finger presses the “+” button on the bottom control panel. Small black monitor showing OSD menu; a finger presses a button on the lower control panel. Small black monitor with picture settings menu in the top right, finger pressing a bottom bezel button
    This is what Elektroda.co.uk looks like on the monitor, loaded via HDMI.
    Small black monitor on a desk showing elektroda.pl, with control buttons along the bottom bezel Small desktop monitor displays the elektroda.pl website via HDMI; control buttons are visible on the bezel. Small black monitor on a desk displaying the elektroda.pl website via HDMI.
    The viewing angle is not bad:
    Small black monitor on a desk held by a hand, with a cable connected and a web page displayed on the screen
    Immediate response time (comparison against laptop screen, connected via HDMI):
    And then there's the foot - it could be heavier, but it still holds up:
    Adjustable black stand and mount of a small monitor, rear view on a white background Rear connector panel of a monitor with DC power, VGA, HDMI, and three RCA jacks
    Test with photos on USB:
    USB 2.0 menu on a small monitor with PHOTO, Music, Movie, and TEXT icons on a dark screen. Small black monitor showing a USB photo browser grid with thumbnails Small monitor showing USB photo browser with thumbnails; a finger presses the MENU button on the bezel
    Small monitor with media player UI, showing a photo of a metal power supply in a blue perforated case. Small monitor with black bezel shows a close-up of a circuit board and an on-screen media player control bar.
    Test with camera on BNC connector:
    Small monitor screen showing “Input Source” menu with BNC highlighted Small black monitor shows a close-up of a light bulb; another bulb and a hand are visible on the desk.
    Monitor connectors: BNC, RCA jacks, and two USB ports, with a BNC cable plugged in Small monitor with a black bezel shows a camera feed; a tiny bulb is visible above the bezel and on screen.
    Power consumption in standby and when switched on:
    Small monitor showing elektroda.pl and a UNI-T power meter reading 5.2 W and 65.25 UNI-T power meter with plug, showing 0.0 W and 65.25; black monitor in the background
    In summary , the monitor seemed a bit pricey to me, even though I ordered it at a bargain price - I see it's even more expensive now, but surprisingly the kit and its construction compensates for this to some extent. You get it with all the cabling, power supply and leg. I also rate the image and viewing angle as acceptable. A purchase can be considered.
    And what is your opinion, what small monitors do you recommend?
    p.kaczmarek2 wrote 14827 posts with rating 13015, helped 659 times. Been with us since 2014 year.
  • Camecho monitor closely matches Podofo model
    #2 21872439
    LA72
    Help: 648
    Rate: 1666
    How similar he is to Podofo, bought for 127PLN's.
    Back of a black LCD monitor with ventilation grilles and several metal connectors along the bottom edge Open cardboard box with two gray items wrapped in protective foam Portable monitor kit: screen, remote, power adapter, and HDMI, VGA, and AV cables on a wooden surface Black flat monitor with AV1/AV2 and MENU buttons on the lower bezel, screen off Rear connector panel: power, VGA, HDMI, RCA AV, audio, USB, and antenna jack Rear connector panel: power, VGA, HDMI, RCA AV, audio, USB, and antenna jack
    I bought mine with retro computers in mind, it has the right connectors.
  • Interlace and NTSC-50Hz compatibility questions
    #3 21872494
    gregor124
    Help: 103
    Rate: 894
    I would be interested to know how this monitor works with, for example, analogue equipment such as a VCR.
    Does it, and if so, how does it work in interlace mode?
    Such information could help users wishing to connect older equipment, such as an Amiga computer.
    Personally, I am looking for a monitor capable of displaying a colour image in NTSC-50Hz mode, although I understand that it is not easy to find equipment that works in this standard nowadays.
  • #4 21872504
    LA72
    Help: 648
    Rate: 1666
    gregor124 wrote:
    This information could help users wishing to connect older hardware, such as an Amiga computer.
    Amiga 1200 in Hi-Res works fine.
    The same for the C=64 and Atari 800xl and PSX to PS3 consoles.
  • #5 21873696
    airman
    Rate: 40
    >>21872311 Well I didn't get to read what the power consumption was measured. Generally you buy a lot of stuff from china, recommend something that gobbles little and gives a lot to the camera as a preview monitor.
TL;DR: The 10-inch Camecho uses a 12 V 2 A supply, and one user said the image and viewing angle were "acceptable." This FAQ helps Raspberry Pi, CCTV, and retro-hardware users judge whether a cheap 1024x600 monitor solves mixed HDMI, VGA, RCA, and BNC display needs without buying blind. [#21872311]
Why it matters: Small workshop and camera monitors often look identical online, so real user tests on inputs, accessories, and analogue compatibility matter more than marketplace listings.
Feature Camecho 10" monitor Podofo 10" monitor
Price mentioned PLN 100-200 PLN 127
Included/mentioned inputs HDMI, VGA, RCA, BNC, USB Chosen for retro-computer connectors
Intended use in thread PAL camera, HDMI desktop, USB media Retro computers
Reported build impression Surprisingly solid Described as very similar
Key insight: The strongest takeaway is versatility, not panel quality. This class of 10-inch monitor is useful because it combines HDMI computer use, CCTV-style BNC input, and older hardware compatibility in one small screen.
  • The thread describes a 10-inch, 1024x600 LCD monitor sold for roughly PLN 100-200, depending on promotions and seller. [#21872311]
  • The kit includes a remote control, a 12 V 2 A power supply, and cables for HDMI, VGA, RCA, and BNC, which reduces setup cost. [#21872311]
  • The monitor supports USB playback for photos, music, and movies, plus picture, aspect-ratio, colour-temperature, sound, clock, sleep, and OSD-language settings. [#21872311]
  • A second user reported a very similar Podofo 10-inch unit bought for PLN 127 specifically for retro computers because it had the right connectors. [#21872439]
  • Retro compatibility reports in the thread include Amiga 1200 Hi-Res, C64, Atari 800XL, and PlayStation PSX to PS3 working on this monitor type. [#21872504]
How much power does the Camecho 10" LCD monitor use in standby and during normal operation?
The thread confirms that standby and switched-on power were measured, but it does not provide readable numeric watt results in text. The only hard electrical figure stated is the included 12 V 2 A power supply, so the post documents the test setup rather than a clear standby-versus-on power table. [#21872311]
How well does the Camecho 10-inch 1024x600 monitor work with a Raspberry Pi over HDMI?
It appears suitable for a Raspberry Pi over HDMI, but the thread does not show a direct Raspberry Pi test. The author displayed a desktop webpage over HDMI and judged the image and viewing angle acceptable on the 1024x600 panel, which supports the idea that Pi use is practical for light GUI work. [#21872311]
What accessories and cables are included with the Camecho surveillance monitor kit?
The kit is unusually complete for this price class. It includes a remote control, a 12 V 2 A power supply, and cables for HDMI, VGA, RCA, and BNC, plus the monitor stand. That bundle matters because mixed analogue and digital inputs often require separate cable purchases. [#21872311]
How good are the viewing angles and response time on the Camecho 10" LCD monitor compared with a laptop screen?
The viewing angles looked acceptable, and the author described the response as immediate in a side-by-side video with a laptop screen. The thread does not give milliseconds, but it does show a direct HDMI comparison and states that the angle performance was "not bad" for a 10-inch budget display. [#21872311]
How does the Camecho monitor perform when connected to a PAL camera through the BNC input?
It works with a single PAL camera through the BNC input and produced a usable live image in the posted test photos. "BNC" is a coaxial video connector that carries analogue CCTV signals, uses a locking twist fit, and is common on surveillance cameras and compact preview monitors. [#21872311]
What multimedia features does the Camecho monitor support over USB, such as photos, music, and movies?
It supports USB playback for photos, music, and movies. The on-screen menus shown in the thread also include picture controls, aspect-ratio changes, colour-temperature options, sound settings, a clock, power on/off timing, sleep timing, and OSD language selection. [#21872311]
How does this monitor handle older analogue equipment like a VCR, especially in interlace mode?
The thread does not answer that fully. One user specifically asked about VCR use and interlace handling, but no follow-up test results were posted for a VCR or for interlaced analogue modes. That missing data is the main edge case if you need guaranteed support for older video gear. [#21872494]
What results can users expect when connecting retro hardware like an Amiga 1200, C64, Atari 800XL, or PlayStation consoles to this type of monitor?
Users can expect basic compatibility with several retro systems, at least from the forum reports. One user wrote, "Amiga 1200 in Hi-Res works fine," and added that the C64, Atari 800XL, and PSX to PS3 consoles also worked on the same monitor type. [#21872504]
What kind of monitor can display a colour image in NTSC-50Hz mode for older video equipment?
The thread does not identify a monitor that is confirmed to show colour in NTSC-50Hz mode. A user said they were looking for such a display and noted that this standard is hard to support today, so the post raises the requirement but provides no verified model recommendation. [#21872494]
Camecho vs Podofo 10-inch monitor: which one is better for retro computers and mixed analogue/digital inputs?
The thread does not prove that either one is better overall; it only suggests they are very similar. Camecho is documented with HDMI, VGA, RCA, BNC, and USB, while the Podofo was bought for PLN 127 because it had the right connectors for retro computers. Choose by connector set and price, not by claimed brand difference. [#21872439]
How do you measure the real power consumption of a small 12 V monitor like the Camecho?
Use an inline power meter on the monitor’s supply and compare standby with active display operation. 1. Connect the monitor with its 12 V 2 A adapter. 2. Measure once in standby and once when switched on. 3. Repeat with a real source, such as HDMI or camera input, because load can change with active use. [#21872311]
What is a BNC connector, and why is it commonly used with CCTV cameras and surveillance monitors?
A BNC connector is the standard analogue video link in this monitor’s CCTV-style setup. "BNC" is a coaxial connector that carries composite camera video, locks mechanically with a twist action, and is widely used where fast, secure connections matter in surveillance wiring. [#21872311]
What is PAL video, and how is it different from NTSC when using small LCD monitors?
The thread only confirms a working PAL camera test and mentions a separate search for NTSC-50Hz colour support. "PAL" is an analogue colour-video system that small CCTV monitors often accept through composite or BNC inputs, while NTSC refers to a different analogue format that may not behave identically on modern LCD scalers. [#21872494]
Which small low-power monitor is best as a camera preview screen for CCTV or workshop use?
This thread points to the 10-inch Camecho-style monitor as a practical option, but it does not prove it is the best. Its advantages are the small size, bundled 12 V 2 A supply, included cables, and working PAL camera over BNC test; its main weakness is missing clear published watt figures from the measurement. [#21872311]
Why do small 1024x600 HDMI monitors sometimes look acceptable for desktop use despite their low resolution?
They can look acceptable because screen size matters as much as raw pixel count. In this case, the author showed a desktop page over HDMI on a 10-inch 1024x600 panel and still rated the image and viewing angles acceptable, which is enough for monitoring, settings menus, and light workshop use. [#21872311]
